Not sure about compatibility. But compression ratio is enough of a problem here. Even if you can use low comp pistons and thick metal gasket, remember, you are compressing air/fuel from a 2.0L block into a 1.6L head. Might have to send to engineering shops for grind some of head metal off in the combustion chamber.
I got all my lights changed to white LED. Even my low beam is white LED. But the high beam unfortunately is 90/120W Hella yellow.... I want white lights.... I am very much aware that HID of any candlelight watt is illegal. So moving on to Halogen bulbs. But what about white "halogen" bulbs? Raybrig? PIAA? Philips? Are they legal from JPJ? I asked THREE shops already... All answered the same thing.. Either not sure or JPJ will tahan but they check if HID or not and will let go if halogen...
