Car can't start on 1st crank..
ehdrian
I Don't Care!
3,310
280
1,683
Penang
hey guys, me using stock 4g93t on my sgti..lately, i've difficulties crank starting my engine when the engine is cold or not running for few hours...it can't start on 1st crank, usually 2nd crank only can start..using denso iridium ik22 plugs for abt half year..battery just replaced 3months ago..fuel pump just changed few weeks ago..i've ask my mech regarding this prob, he say starter isn't the culprit..converted almost 1.5years ade..can somebody help me with this prob?..
Shanashi
679
17
check ur
1) dirty throttle body <-- normal case if ur using open pod
2) maybe batt faulty
3) fuel pump <-- fuel pump changed d right
4) starter motor <-- new one only RM100+ someone here selling VR4 starter dono still got anot
ehdrian
I Don't Care!
3,310
280
1,683
Penang
popout: battery just changed 3months ago..
Shanashi: i tot abnormal timing only cause by dirty TB...does it affect in my case?...battery just changed 3months ago..fuel pump changed 2weeks ago...my mech say not starter motor..haih..pening..:banghead:
popout
366
last time i also encounter this kind of problem first time is battery weak then kong dy change a new one , new battery also will cause cranking problem but since ur battery dy 3 month i think not batt problem. my suggestion is to but a injection cleaner like STP one pour into ur fuel tank and see still happen or not. last i try cuse of the fuel regulator dirty dy, and walak it can start like normal on first crank. ps:i also using 4g93 but not turbo haizzzz
huakenny
LB Performance
9,126
240
3,163
Kota Kinabalu
to see battery weak o not...
simplest wat is use another battery, jumper it to ur car battey....(use jumper cable)
and start ur car
if still the same...then not battery problem....
if problem solved, mean batery problem
Shanashi
679
17
stp injector cleaner works ka huhu wats ur mileage when u used it? i must also do preventive maintenance
ehdrian not necessary when TB dirty got cranking probs...must step on gas dam pening that time tot something wrong after cleaning starts like a new car man....that time using sohai air filter thats why dam dirty....:bawling:
ehdrian
I Don't Care!
3,310
280
1,683
Penang
will go and buy stp injector cleaner tmr and hopefully it will solve the prob..how many bottles do i need?..i just washed my K&N open pod last month..
risyia
168
30
3,028
Pandan Indah
Bro,
Are u using Adjustable Fuel Regulator (AFR) that is connected by a long rubber hose from the fuel rail to the AFR.
This could be the problem as it takes a few cranks before it can build pressure to squirt fuel into the injectors, due to the long hose.
ehdrian
I Don't Care!
3,310
280
1,683
Penang
Risyia: i don't have AFR..thanks anyway..the car can start on 1st crank ade but must crank slightly longer than previously when the car used to be in tip top condition..
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
to crank ur engine, u jz need a few items...
- sufficient battery voltage
- working starter
- distributor/coil/sparkplug
- fuel pump/injectors
speed2horizon
2,798
334
1,683
Bro,
I was about to mention this when I was reading through the thread. But the problem is not about the long hose.
The problem is some of the after market adjustable fuel pressure regulator does not retain fuel after you shut down the engine. However, it can be tested with a pressure gauge. If the fuel pressure drops immediately after shutting down the engine... Fuel pressure regulator lar tu....
The stock FPR does not allow drainage within the fuel rail. Hense, the fuel pressure can be maintained.
Regarding the injectors, if u shut down the engine for 5 minutes, even before the engine cools down, the same problem will appear.
Exhaust..? what does it have to do...? When trasplant the engine, before pasang the exhaust the engine still starts on the first crank. Bising lar...
About the leakage of IC piping... U will feel the engine feels like wanna doe of even when u are driving.
All mentioned are based on persinal experience...
Japan’s Car Top magazine has been informed in detail of Nissan’s secret test drive event held earlier this month&nbsp;at its Tochigi proving grounds.</p><p>An unnamed&nbsp;test driver&nbsp;has spoken exclusively to Car Top magazine about an event held by Nissan to allow 30 people to test drive the 2008 GT-R at its Tochigi proving grounds earlier this month. No media representatives were invited...
