Changing Iswara gearbox oil seal pricing
bass1664
Sep 29, 2023
5
18
Hi guys, recently I found my gearbox to be leaking oil but not very severely. I went to 2 mechanic workshops to get a diagnosis and quotation on fixing the issue, both of the workshops said it was the oil seal that needs to be replaced. The first one said it was the right side oil seal which I assume is the driver's side driveshaft seal that is leaking, he quoted me around rm120 to replace it, rm40 for each seal and rm40 for labor charge. The second workshop I went to earlier, they took a look and said it was the inner oil seal that is leaking which I assume it's the flywheel oil seal and said it would cost about rm600-700 to change it because they need to remove the entire gearbox bla bla bla. Which one should I go for? Currently also a uni student so I've a tight budget but I also want to not waste money tbh.
bass1664
5
18
Nvm, got it done today and the driveshaft seals were replaced, no more leaking. Mech charged rm70 for the job too so it's probably just replaced the leaking side
Glad you got it done, means the second workshop was trying to cut throat......
Naza Automotive Manufacturing (NAM), the manufacturing arm of the Naza Group, has invested RM30 million for a new robotic assembly line at its plant in Gurun, Kedah for the new Peugeot T73.
<!--more-->The new assembly line is the first line at NAM's facility in Gurun with automated robots to ensure the quality consistency for the T73, which is a new C-segment Peugeot that will be launched for the...
