Not sure about compatibility. But compression ratio is enough of a problem here. Even if you can use low comp pistons and thick metal gasket, remember, you are compressing air/fuel from a 2.0L block into a 1.6L head. Might have to send to engineering shops for grind some of head metal off in the combustion chamber.
Hello, bros.. recently i found another extra voltage stabilizer which is hot inazma and the one i am using currently is raizin so just wondering can any experts here tell me that whether a not i can install both of the voltage stabilizer in my wira ?? meaning 2 voltage stabilizer, will it causes more harm than good?
