1st generation mivec head on evo3 block.
DemonicxZ`
85
Anyone done this?:)
Can this be done?
if cant what is the main problem ?
thx all sifus in advance :D
xtremeleo
3,247
464
i dont think it can be done sir, not witout much work imo. the formulas are different between the engine head and block
Veloc
3,234
991
Sabah
Not sure about compatibility. But compression ratio is enough of a problem here. Even if you can use low comp pistons and thick metal gasket, remember, you are compressing air/fuel from a 2.0L block into a 1.6L head. Might have to send to engineering shops for grind some of head metal off in the combustion chamber.
Shinjite
864
120
Klang
Both are totally different engine models.....
If tranverse engine (EVO 4 onwards), can only source EVO 9's MIVEC head
afariq
371
4g9x series head will not fit 4g6x series block. Usually they'll go the 4g94 route..
(ADVAN)
523
5
K.L
erm..since when 4g63 & 4g93 can be mix up?
u asking the same question whether RB26 head can b used in 2JZ block..
nikolaiski
88
36
Because nowadays EVERYTHING also pple mix up mah :P so some ppl curious...heh heh..
I was wondering last time also if I could bolt on the Evo 9 MIVEC head onto a 4G93 terbalik. Apparently not...
calvin9683
1,768
171
JB
y would u wanna put evo9 mivec head to a 4g93 terbalik when u can use CK model mivec head???
nikolaiski
88
36
because the answer is simple: EV0 9 HEAD + ECU > 4G92 MIVEC HEAD + ECU...wahahaha..at least in terms of "newness" lah
but seriously, singapore quite a few ppl selling at one time...some more same price as the CK MIVEC head..so was wondering if can or not :P
joe_mirage
1,030
44
rotationperminute.blogspot.com
why dont 4g63 2nd gen cylinder head + 1st gen 4g63 block XD ? this one can be done.
