DIY LED brake lights. Need help.
TitanRev
You think I print money?
Mar 3, 2005
8,210
3,678
Much neat now...nice....I'm very fond of neat DIY job..It makes those half pass six acc shop guys look like newbie when they see our work...
shiroitenshi
3,677
170
ohms law. Better use the lm7805 linear regulator. just like the lm7809 suggested in smarttag thread.
shiroitenshi
3,677
170
i just found out about them in the smartag thread.. i bought them and tried.. they really work! much better than using resistors because can stick a heatsink on them...
goohtj
57
12
5,008
Bro, lm7805 is 5v, how you connect? 2 x leds in serie or 1 x led + resistor per set?
goohtj
57
12
5,008
use a lm7809 to produce 9v n connect 3 x 3v leds in series per bank.
led voltage = 3v so 3 x 3led = 9v so no resistor required.
say 12 leds required for your brake light.
you need 4 banks. each bank draws ~25ma current = 100ma.
lm7809 is 1,000ma ~1,500ma loading. or can easily connect up to 40 banks or 120 leds
input voltage = 11v ~ 35v, power consumption = 2watts (14v x 100ma + some powerloss)
advantage of this DIY.
Cheap (RM3) only.
same led brightness when car is started (14v) or not (12v).
option 2. simpless DIY.
connect 5 leds in series per bank. 5 x 3v led= 15v no resistor required.
brightness is lower.
stupidcar
5,000 RPM
5,567
850
Cheap (RM3) only.
bro, i am asking the smarttag one.
Cheap (RM3) only.
Did not know you sifu in this....:driver:
goohtj
57
12
5,008
Bro, me only major in Electronic n Computer..
Btw, where 2 source for good super bright led? tried pasar rd - not ideal.
stupidcar
5,000 RPM
5,567
850
Bro, eBay. It is cheap. So far so good.
Just be careful before u chose the buyer, see if their ratings are better than 99.8% or not.
If it's less than that, then see the past 6 months, how many complains they got.
levin818
1,260
321
3,183
Shah Alam
It is not a good idea to drive the LED using this method. A proper way should be controlling the current but not the voltage. Reason why is because LED has a very steep V-I curve. A slight changes in voltages will cause a huge changes in current. If the LED has a low side in forward voltage due to manufacturing batch, then it may end up blowing these LED in a short period of time.
shiroitenshi
3,677
170
rs online or element14.com
both got branch in malaysia if you want luxeon leds and drivers
---------- Post added at 01:19 AM ---------- 6 hour anti-bump limit - Previous post was at 01:14 AM ----------
isn't the lm7809 current limited to 1A? Why would it be a problem?
oh, nvm, i get your point, but easily solvable by not running the leds in series right?, so LM7805/LM7809 + resistors + leds in parallel is workable?
btw stpcar, I used the lm7809 + caps for the smarttag, not LEDs.
artful
20
Hi all sifu,
If i need brake light function with my below setting, what type of diode and extra resistor to add??
HPWS-FH00-H4000 Lumileds Superflux LED
Vf : 2.6V(typ)
If : 70mA(max)
Total LED: 17
turning it on with a resistor in the 12V car (maximum voltage 14.4V) about 50mA.
I'm using 【1W 240Ω】 resistor for each superflux LED. Below is the diagram
goohtj
57
12
5,008
Hi all sifu,
Vf : 2.6V(typ)
If : 70mA(max)
Total LED: 17
your is a single led per bank - alot of power loss
why not connect 5 leds in serie per bank
5 x 2.6v = 13v
could add 28ohm resistor ( 14.4v-13v =1.4v / 50ma = 28ohm)
note: this brings up to 15 leds or 20 leds ..
levin818
1,260
321
3,183
Shah Alam
... so LM7805/LM7809 + resistors + leds in parallel is workable?...
Yes connection in this way is better! The LED brightness will not affected by the variation of battery voltage. But the max output current is limited by the type of Voltage Regulator being use.
---------- Post added at 11:57 PM ---------- 6 hour anti-bump limit - Previous post was at 11:53 PM ----------
I personally find this this page is quite informative. It has a simple resistor current control circuit to a more complicated MOSFET constant current driver. Great for those who want to DIY.
http://www.pcbheaven.com/userpages/LED_driving_and_controlling_methods/
---------- Post added 08-12-2013 at 12:00 AM ---------- 6 hour anti-bump limit - Previous post was 08-11-2013 at 11:57 PM ----------
Can someone help me to sort my led brake light issue? I see some experts around here would really appreciate if someone could sort it out.
Is it from 8-series :O
Yes it can be recover. But the plastic cover might need to cut open in order to reach the LEDs inside.
hey guys, recently have check engine light issue after long drive. driving midway on highway and check engine light came out. car was running fine and did not have any signs or feeling or jerks, constraints, etc. i remember having tps issue before as the connection was loose before. Now the connection is good and still cant figure out the check engine light issue. Air flow sensor seems fine, just havent cleaned it cause i dont know where to get the cleaner. Spark plugs havent checked...
