DIY LED brake lights. Need help.
artful
20
Hi levin818,
I was thinking to use 18LED which in 3led x 6bank in order to make easier for wiring for tail n brake light function. From the below diagram highlighted in red, which resistor should i use for 3led x 6bank??
From your LED's V-I curve:
When I = 50mA, Vf = 2.45V
When I = 30mA, Vf = 2.26V
[Brake Light] (+) -- 7809 -- diode ---------┐
[Tail Light] ...(+) -- 7809 -- diode -- 6R2 --•-- 22R -- LED -- LED -- LED ---•-- (-)
.................................................. ..........└-- 22R -- LED -- LED -- LED --┘
Diode = 1N4007, all resistor @ 1/4W 1% tolerance
And another question is how to connect Voltage Regulator IC 7809?? It come with 3pin
[Brake Light]---->(Vol IN)7809(Vol Out)---->diode
(GRD)??? where to connect this?? It is connect to the negative??
Thanks
levin818
1,260
321
3,183
Shah Alam
Hi artful, please see the following:
At I = 50mA, Vf = 2.45V
At I = 30mA, Vf = 2.26V
[Tail Light] ...(+) -- 7809 -- diode -- 5R6 --•-- 22R -- LED -- LED -- LED ---•-- (-)
For voltage regulator:
Connect GRD (center pin) to negative.
---------- Post added at 01:33 AM ---------- 6 hour anti-bump limit - Previous post was at 01:16 AM ----------
After you wire up everything, and when first power on, use a volt meter to make a quick measure the voltage drop across one of the 22R resistor.
At Tail Light function, you should have 0.6V~0.7V (27mA~32mA)
At Brake Light function, you should have 1.0V~1.1V (45mA~50mA)
If the reading is far beyond the range, you might want to disconnect the power immediate and re do the calculation.
shiroitenshi
3,677
170
like i previously told him.. car always calculate using 14.5. now i know got simple linear voltage regulator, makes it even easier, no need to bother with 11v-14.5 v difference when engine running or not.
Sent from my GT-I9100G using Tapatalk 2
stupidcar
5,000 RPM
5,567
850
713
May I ask what is 5R6?
A Post Every 5 Mins
GearBox Code Vehicle Front LSD Ratio
W5M33-2-NGRE Lancer gsr RS (1992, 1800cc) ?
W5M33-2-NNZT Eclipse AWD 5spd mfg 3/94 ?
W5M33-2-NPXV 91-94 Eclipse AWD 5spd mfg 6/90-2/94 ?
W5M33-2-NPZT 95-96 Eclipse AWD 5spd mfg 3/94-6/96 ?
W5M33-2-NQBE Libero/Lancer Gsr, non lsd version of NRWE No 3.545
W5M33-2-NQBK 1991-92 to 4/92 VR4/ZR4 Galant ?
W5M33-2-NQBM 1992 Galant to 5/92 ?
W5M33-2-NRBE 92-95 Lancer GSR, lightweight synco's 2nd & 3rd No 3.545
W5M33-2-NRWE 92-95 Lancer GSR, stronger box, dbl...
