Much neat now...nice....I'm very fond of neat DIY job..It makes those half pass six acc shop guys look like newbie when they see our work...
ohms law. Better use the lm7805 linear regulator. just like the lm7809 suggested in smarttag thread.
i just found out about them in the smartag thread.. i bought them and tried.. they really work! much better than using resistors because can stick a heatsink on them...
use a lm7809 to produce 9v n connect 3 x 3v leds in series per bank.
led voltage = 3v so 3 x 3led = 9v so no resistor required.
say 12 leds required for your brake light.
you need 4 banks. each bank draws ~25ma current = 100ma.
lm7809 is 1,000ma ~1,500ma loading. or can easily connect up to 40 banks or 120 leds
input voltage = 11v ~ 35v, power consumption = 2watts (14v x 100ma + some powerloss)
advantage of this DIY.
Cheap (RM3) only.
same led brightness when car is started (14v) or not (12v).
option 2. simpless DIY.
connect 5 leds in series per bank. 5 x 3v led= 15v no resistor required.
brightness is lower.
bro, i am asking the smarttag one.
Cheap (RM3) only.
Did not know you sifu in this....![]()
Bro, me only major in Electronic n Computer..
Btw, where 2 source for good super bright led? tried pasar rd - not ideal.
It is not a good idea to drive the LED using this method. A proper way should be controlling the current but not the voltage. Reason why is because LED has a very steep V-I curve. A slight changes in voltages will cause a huge changes in current. If the LED has a low side in forward voltage due to manufacturing batch, then it may end up blowing these LED in a short period of time.
Hi all sifu,
If i need brake light function with my below setting, what type of diode and extra resistor to add??
HPWS-FH00-H4000 Lumileds Superflux LED
Vf : 2.6V(typ)
If : 70mA(max)
Total LED: 17
turning it on with a resistor in the 12V car (maximum voltage 14.4V) about 50mA.
I'm using 【1W 240Ω】 resistor for each superflux LED. Below is the diagram
... so LM7805/LM7809 + resistors + leds in parallel is workable?...
Can someone help me to sort my led brake light issue? I see some experts around here would really appreciate if someone could sort it out.
Similar threads | |
