BMW 320i e46 or altezza??
  • BMW 320i e46
    Votes: 0 0.0%
  • Toyota Altezza SXE10
    Votes: 0 0.0%
  • Total voters
if your dad has passions in beemers then get 1, u wont regret.
like my cousin he & his dad has an MR2 each.....both of them rebuild their cars at home, they share the same passion.
Gah, rebuild rebuild. I've been dreaming about it. Everyday read build threads.
---------- Post added at 03:29 PM ---------- 6 hour anti-bump limit - Previous post was at 03:29 PM ----------
Too bad, TS doesn't prefer a 2 door car. Else, Satria or Putra would be a good choice for him to start learning about modification. Plenty of modification can be done to the 4G engine and yet it is not that expensive.
The maintenance of a BMW is not cheap at all even though I don't own one.
Izso's Wira also 4G mahahahaha
Trust me, i want a two door . But u know la, have to fetch family go gaigai. Im not even thinking about the bmw anymore hahaha
Newbie
---------- Post added at 03:41 PM ---------- 6 hour anti-bump limit - Previous post was at 03:37 PM ----------
My dad likes bimmers and mercs cuz they look classy haha.
Rebuilding a car with my dad? Haha the only thing he knows is engine displacement. Everytime he sees a car thats 2.0 he'd be like that car very powerful . I do hope i get to rebuild a car with my bro tho
Newbie
---------- Post added at 03:42 PM ---------- 6 hour anti-bump limit - Previous post was at 03:41 PM ----------
The stroker kit and oversized pistons combo will easily increase your horsepower to touch 100bhp easily. But a little more will be needed to hit 140bhp dude. Once you're ready to pull out your 4G15 I'll teach you :biggrin:
Don't know yet. Perfect la. Gives me time to think and gives you time to prepare. Hehehe.
Yeah exactly. What how much did ur wira get on the dyno?
Newbie
OK. 2 door car is out since have to fetch family members go gai gai.
May be you should consider of getting a cheap stock standard car and start your modification project.
Project NA (Naturally Asipirated) : either VTEC or MIVEC
Project turbo : Evo III or RB20 lorrrrrr....
My newbie 2 cent.
Throw in Plastic dip two orange ears.......:driver::biggrin::biggrin:
Aiyah! Bring for DIT we polish up for you too......
Polish mine too :rofl:
I got a Wira which is inherited from my family. Good enough for me but still feel a little not satisfied because lack of budget and proper knowledge to mod it.
If bought yours, what am I going to do with my car? Already a little tight on budget because of the fees for uni... Don't dare to request for a change of car.
Sell off yours and buy Izso's one. You bought yours how much?
Hardcore ones have how many hp by average for NA mod. Previously you mention 4G18 crankshaft + 77mm CFE pistons can get around 120-140hp is it?
So, change into high flow filter will allow more air to enter the engine. Which means that the injectors will spray more fuel to burn the extra air to compensate? Correct me if I am wrong.
Not proven save fuel nor more fuel consumption. To me, I just want to save on buying the ori air filters which cost RM80. Might as well I get a K&N which I can reuse it.
Agree with you bro. Can't really prove the fuel efficiency or the performance after install aftermarket air filter (regardless drop in or open pod). Most important is can reuse it. I can wash it anytime I want. :proud:
Ok guys lets not talk about buying over my car anymore, if anyone is interested just PM me. We can talk.
hgbee : Dyno-ed the car 3 times that's worth while mentioning. Stock auto, after rebuild still auto and after another rebuild with manual.
The sad thing is the figure started low, then went up, then went back low again. Hence my need to mod the head again. I can't understand why the 2nd rebuild reduced my bhp by 10bhp.
Izso mentioned several times that more fuel + more air = more power.
Yup, fuel + air = power. The more fuel + air as in displacement or forced induction = more power.
High air flow, how to get more fuel? unless you cheat the ECU, then restricted as injector too small, then change to bigger injector and so on and on and on = mod and mod and mod.....hahahahaha:biggrin:
Sifu then sifu. Pointed out the injectors. Hahha. I also didn't thought of that.
Depends one lah. Super subjective.
Btw, nice find lol. I didn't know the existence of the threads.
Civic EG9 or EK4 also can be considered. Although ori EG9 and EK4 is rare, there are still converted ones fitted with B16A,B16B,B18C or B18C Type R.
You need to give me some time first. When the time comes, I'll seek advice from you for sure. :biggrin:
4G got a lot of series. 4G1 series, 4G9 series, 4G6 series. :biggrin:
Mine bought for 40k plus. Around 15 years ago. Bought by my dad but he's not around anymore, if you know what I mean.
I thought the stock ECU will compensate and inject more fuel from the injector due to extra air?
4G15 only lahhh.
Dude, u used the 'if you know what I mean' so wrongly.
Stock vs stock injector should be okay. Unless BOT then cannot dy. Pushing more than what the stock injectors can go I guess.
Yes, a stock ECU will calculate the amount of air going in as in mass air sensor, MAP sensor and so on, but the injector also have it's limitation, that is why got bigger cc injectors for mod....
4G15 only lahhh.
Sorry that I used it wrongly. I should just say passed away.
You mean if BOT, then stock injectors can't handle it? Sure because of the extra compressed air from the turbine is entering.
So, changing into high flow air filter won't affect FC at all or perhaps just little bit?
No, what I meant is, the injectors will need to pump more fuel, but it doesn't have the capabilities to do so.
U turbo dy sure need more fuel ma, if not lean dy lo. Hence, 470cc or what 900cc injectors, just for example.
Sent from my Lumia 925 using Tapatalk.
That's what I am saying earlier. I say injectors can't handle it because of the extra compressed air. Meaning like more air entering the engine but not enough fuel from the injector because the stock injector is at its limit.
So means I can use Celica Injectors :rofl: Need to get my KNN oil ASAP after washing.
No worries bro, don't bother. You didn't use it wrongly. Sorry to hear about that. Didnt meant to bring that up again.
K&N mine is drop in, FC wise you won't really notice at all. Open Pod I'm not sure.
Nevermind bout that, I din't mention that you brought that up. Besides, its has already happened for years already. Regrettable but life is always full of challenges and hardship.
So, drop in won't affect FC much... I think I can consider getting one for my car. Open pod I heard that power will gain at top end but lose at low end.
Open pod need to heat shield or CAI, if not suck hot air only....
Kudos to mum though. Shes tough.
Sole bread winner/?
Last time my friend put open pod on Kancil. Looks very weird. But I remember that he is saying that he's using Kelisa 1.0's block and pistons.
attachment.php
Sole bread winner/?
Yeah, sole bread winner. Not really earning a big salary though. Still relies on old savings if more money is needed.
attachment.php
Directly in the hot air path of the radiator fan so more.....:banghead:
