DIY LED brake lights
L9Turbo
274
Well.. I tried for my 3rd brake light. it didnt last long. abt 2 weeks. At first very bright. nice. sigh... spent RM 60 for the LEDs :( anyone knows where to get top grade LEDs?
prodigy
2,786
forget about buying from jalan pasar if you want top quality electrical components. go for Farnell or RS at shah alam. their components are definitely more expensive and are top grade ones as compared to jalan pasar. electrical components are generally categorised into 3 grades. grade 1 components normally goes to people like farnell or RS. quality is guaranteed. grade 2 goes to manufacturers or fabricators of PCB. or actually vice versa, depending on the QA/QC of the manufacturer. grade 3 components goes to, none other than jalan pasar.
ysyep
5
Plan to do it also, but since L9Turbo said rosak so fast, might need to consider now :P
alantan
3,573
15
kl
my trhid barake ligh always fell off eventhough..i stick and replace the double sided tape for liek 10 times..
any solution for this?
escaflowne
1,006
yeah mine too...too old the 3rd brake light...the color also soooooo pudar.
but i think the LED after some sun heat treatment...will said bye bye one rite??
ksgoh
1,392
9
Kedah/Penang
go for good double sided tape...like NITTOTAPE...however, it cannot stand for heat too..... :(
L9Turbo
274
The LEDs i bought and used was very good when new. But only lasted for 1 to 2 weeks.. then one by one die off. I am located in JB BTW. Dunt like the bulb looks. :)
L9Turbo
274
Maybe.. but the shopkeeper said for 12V is in a set of 3 LEDs. So i installed 33 LEDs. Anyone good in electronics here?
L9Turbo
274
wait i take pic then show u. err.. any good free pic host site? Then i can link it over.
khguan
4,818
26
Seri Kembangan
fotopic.net
the reason ur LED burn is bcos de car batt voltage is much higher than de LED's voltage..
u have to use a combination of series n parallel connection in order to use many many LEDs so dat each LED only take 3v
another way is go n find 12v LEDs... then u can connect directly... (parallel connection)
L9Turbo
274
Yeah.. tat's better. But is there 12v LEDs? Price of each is how much?
ksgoh
1,392
9
Kedah/Penang
Originally posted by L9Turbo+Sep 24 2004, 16:44 --></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (L9Turbo @ Sep 24 2004, 16:44 )</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-khguan@Sep 24 2004, 14:44
Yeah.. tat's better. But is there 12v LEDs? Price of each is how much? [/b][/quote]
yes, but that is not called LED liao....is called bulb...hehehe... :P dunno got or not, but i never see it....
L9Turbo
274
Wow!! Very informative! Thanks bro.. Will DIY my lights again. Hehehe.. But this time with less LEDs. Broke liao. :P
JasperSSP
131
There are 12v LEDs in the market. It is used in industrial machines. but I dunno whether you can get it from the electronic shop or not.
L9Turbo
274
HHmmm... maybe very hard to find them. And cost.. dunno how much. But less hassel... no need put resistors rite? Just straight connect?
Hi bros,
I have a few questions here.
Last week i re-installed my Vacuum Gauge from my old car (Iswara 1.3) to my Vios '05.
Due to the Vacuum hose is too big in diameter (8mm) for the T-joint (to the sensor), I changed the hose to a small diameter (7mm).
Question is:
1.) will it affect the engine if i change the hose diameter to a smaller size?
2.) the mechanic said that Vios is not advisable to intall a Vacuum Gauge as it need sufficient air. Is this true? I have not come...
