DIY LED brake lights
L9Turbo
274
Wow!! Very informative! Thanks bro.. Will DIY my lights again. Hehehe.. But this time with less LEDs. Broke liao. :P
JasperSSP
131
There are 12v LEDs in the market. It is used in industrial machines. but I dunno whether you can get it from the electronic shop or not.
L9Turbo
274
HHmmm... maybe very hard to find them. And cost.. dunno how much. But less hassel... no need put resistors rite? Just straight connect?
khguan
4,818
26
Seri Kembangan
fotopic.net
yes... there are 12v LEDs.. but rare.. u can find them in electronic stores...
got in big size somemore... 10mm diameter... but more expensive.. duno de price...
L9Turbo
274
I'll go get the 12v LEDs this week. But how to connect? Just in series? or parrell? No need resistors then?
ctan13
33
I think you will need to check with the shop what sort of current the LEDs need. Based on that, you will then need to calculate the value of the resistors using the formula as stated in the link given by InitialD and myself. 12V LEDs doesn't mean that you can just plug them into a 12V supply ... it also depends on the current. I'm no electronic expert, but that's what I understand from all that I've read.
sharkair
27
just an opinion. switching circuit will be having current spike in it. current is equivalent to rate of voltage changes over time (dV/dt). the voltage travel from 0 to 12V within a very short time. this introduce spike in switching circuit.
however, this effect (current spike) can be dampened by putting a capacitor across +/- terminal.
My point is, better to use capacitor across power supply if you want to have your simple LED life longer. The circuit is good, but current protection must be there.
http://www.web-ee.com/Schematics/Brakes/brakes.htm
L9Turbo
274
Thanks for the input! :)
Cheers
This powerful Mazdaspeed Mazda 2 is going to rock your world -- all Mazda fans!
Small compact 4 doors hatch super mini crunches by a 2.0 DISI diesel engine with turbocharged 4 cylinder, clock a 230bhp and 230lb-ft of torque will blows most of us away, not to mentioned a 6 speed closed ratio gearbox.
But the sad news is only Japan now have this model to be sold on the road, no to US and Europe...
