BMW 320i e46 or altezza??
  • BMW 320i e46
    Votes: 0 0.0%
  • Toyota Altezza SXE10
    Votes: 0 0.0%
  • Total voters
I thought the stock ECU will compensate and inject more fuel from the injector due to extra air?
Yes, a stock ECU will calculate the amount of air going in as in mass air sensor, MAP sensor and so on, but the injector also have it's limitation, that is why got bigger cc injectors for mod....
RENESIS VIII
7,063
950
Ipoh
4G15 only lahhh.
Dude, u used the 'if you know what I mean' so wrongly.
Stock vs stock injector should be okay. Unless BOT then cannot dy. Pushing more than what the stock injectors can go I guess.
Sorry that I used it wrongly. I should just say passed away.
You mean if BOT, then stock injectors can't handle it? Sure because of the extra compressed air from the turbine is entering.
So, changing into high flow air filter won't affect FC at all or perhaps just little bit?
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
No, what I meant is, the injectors will need to pump more fuel, but it doesn't have the capabilities to do so.
U turbo dy sure need more fuel ma, if not lean dy lo. Hence, 470cc or what 900cc injectors, just for example.
Sent from my Lumia 925 using Tapatalk.
RENESIS VIII
7,063
950
Ipoh
That's what I am saying earlier. I say injectors can't handle it because of the extra compressed air. Meaning like more air entering the engine but not enough fuel from the injector because the stock injector is at its limit.
Supra_Fanatics
20,673
3,998
Yup, fuel + air = power. The more fuel + air as in displacement or forced induction = more power.
High air flow, how to get more fuel? unless you cheat the ECU, then restricted as injector too small, then change to bigger injector and so on and on and on = mod and mod and mod.....hahahahaha:biggrin:
So means I can use Celica Injectors :rofl: Need to get my KNN oil ASAP after washing.
Civic EG9 or EK4 also can be considered. Although ori EG9 and EK4 is rare, there are still converted ones fitted with B16A,B16B,B18C or B18C Type R.
You need to give me some time first. When the time comes, I'll seek advice from you for sure. :biggrin:
4G got a lot of series. 4G1 series, 4G9 series, 4G6 series. :biggrin:
Mine bought for 40k plus. Around 15 years ago. Bought by my dad but he's not around anymore, if you know what I mean.
No worries bro, don't bother. You didn't use it wrongly. Sorry to hear about that. Didnt meant to bring that up again.
K&N mine is drop in, FC wise you won't really notice at all. Open Pod I'm not sure.
RENESIS VIII
7,063
950
Ipoh
Nevermind bout that, I din't mention that you brought that up. Besides, its has already happened for years already. Regrettable but life is always full of challenges and hardship.
So, drop in won't affect FC much... I think I can consider getting one for my car. Open pod I heard that power will gain at top end but lose at low end.
Open pod need to heat shield or CAI, if not suck hot air only....
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
Kudos to mum though. Shes tough.
Sole bread winner/?
RENESIS VIII
7,063
950
Ipoh
Last time my friend put open pod on Kancil. Looks very weird. But I remember that he is saying that he's using Kelisa 1.0's block and pistons.
Sole bread winner/?
Yeah, sole bread winner. Not really earning a big salary though. Still relies on old savings if more money is needed.
Directly in the hot air path of the radiator fan so more.....:banghead:
RENESIS VIII
7,063
950
Ipoh
This setup is long gone already. Friend said that his bro took this car and chased a FD3S RX-7. After the chasing when reach home, engine started to leak oil and there goes the Kelisa pistons. After that, swap back to original Kancil 660 block, pistons and filter.
Guys, please tell me how come my brake didn't bite on the way down hill from Genting. The bite only came back after half way down the hill. That was not the first time I got this experience. I encountered the same thing in different cars too. Was that because of the low air temperature?
