DIY- to eliminate gearbox whistling sound??
EvolutionZ
5,000 RPM
5,027
1,448
:itsme:dear guyz,
i am facing some whistling sound from my gearbox, wira 1.5mt yr 2003.
juz changed the gear oil (kinda muddy already - previous owner didnt change on time) and added gear oil treatment. the sound still can hear but not so loud. it gets louder when i am in 4th & 5th gear.
went to mech, they advice either to dismantle all and change the particular noisy bearing or change the whole gearbox which cost me a bomb....
so juz wandering is there any "petua" or ideas to eliminate the sound??
gear shift is smooth and everything is fine....juz only the irritating sound....
any sifus in here can advice.....many thanks ahead....:):driver:
lcchong
84
13
1,508
redo the gear box would much better than buying a used one at chop shop..... but if you hav reliable source, cheaper buying 2nd hand gearbox.....
not very sure actually...... hehe! :stupid:
donCityZ
2,230
33
1,648
better go for repair the gb.
if buy 2nd hand, dono maybe soon the 2nd hand gb also become whistle.
once and for all go to repair it with new parts. better and u know it will last long.
loose_end
3,649
197
Malaysia
Izzit like when you accelerate or decelerate the whistling sound like get higher pitch when you accelerate ?
Mat_Isam
348
10
bro, i'm facing the same problem like mr EvolutionZ.....when accelerate whistling sound and
when 'lepas minyak' sound so noise (gruk..gruk..gruk.) like gearbox nk pecah....
currently using evo 2 4wd gearbox
...before this used evo 3 lsd (same prob but more noise) is there any possiblity sound coming
from clutch....right now using trinity complete set pad n spacer (bought new)....
someone can help me here...TQ.
EvolutionZ
5,000 RPM
5,027
1,448
thanks guyz for the suggestion and advice....i sourced a 2nd hand gearbox and changed it....now it works fine but manual used gearbox is expensive....cheerz
liz@rd
492
57
i thought itu masalah bearing saje ... i used to have that whistling but after changed the main bearing , ok alrdy ... oh well
The Marketplace Top Posts
Hi, I have a Daihatsu Charade which is my everyday working car now... The engine i believe is code name: HC13
I was thinking of changing the analog speedometer to a digital ones... but i was wondering, is there a wire output at the ECU or somewhere that is a variable voltage output for the speed. Need to use this output for the mod...
any one got any idea how to check?
thanks.
