DIY-Gen 2 Front Headlight Low Beam Bulb Replacement
ayen_s
25
40
1,513
Proton Gen 2 Front Position Headlight Bulb Replacement
Tool:
1.Multimeter - 1 unit (for testing)
2.Replacement bulb- 1 unit
Duration: 15-20 minute
Procedure
1. Open up the front hood of your car.
2. Reach your hand to the back of the head light.
3. The low beam head light is at the lower part.
4. Twist the bulb socket counter clock wise to release it.
5. Take out the bulb socket from its slot.
6. Pull the burned bulb from the socket.
Note you can check the continuity of the bulb terminal to ensure the bulb is faulty. No continuity means the filament is broken.
It it black as in picture, confirm to replace it.
7. Install the new bulb to the socket and put back the socket in to the slot.
8. Twist the socket clock wise to lock into its place.
9. Turn on the car light to test.
10. Finish
UPDATED
-The bulb was wrongly identified as the low beam. Its actually the procedure for position light.
idnawse
205
36
perak
its dawn light if not mistaken .. T10
High/Low beam bulb is for H4 bulb (main bulb for headlamp)
idnawse
205
36
perak
never heard ..hehehehe ..but in bahasa pasar..they call it lampu kecik/lampu senja
Booze
155
My bed room "on da BED"
www.defcon.org
Thanks Mate
mottrang
50
5
508
sori 4 asking...
last time i change my waja bulb by myself...
the prob now i cant ejast hi lo beam after that...
only ejas manualy by pull it behind not using screw driver tu pusing2 that ejaster...
mb at the time i want to push pin out that thing gone front n mb loose the place...
so anyone please help... beside change to new one what else i can do... thanx...
arturo
nooB
2,721
1,083
3,213
SateCelupLand
mottrang....did u turn the screw until it just cant adjust anymore? even reverse the adjustment also cant move?
the adjuster is just basically a fixed screw with a plastic nut connected to the reflector bowl...if u turn too much, either the plastic nut came off the screw or reached the end of the screw n wore off...if really turn n no movement...u have to open the headlamp cover to take a look see. happened to me twice. tried changing to a metal nut but it seems they use a non standard size screw. in the end, i put some 2 tonne epoxy inside the plastic nut (just lightly coat the insides to add material so the screw has more material to dig into) n covered back the headlamp...hard to imagine...but once u open n take a look you'll understand.
mottrang
50
5
508
nope... jes turn a few time till my hand lenguh but nothing change... :bawling:
btw thanx for the explanation... i will look for it when i am free... huhu
only jes wanna know how to open it... what i can see is only got 3 skru... 2 at the same line with radiator panel 1 down near that air box... got any else...
radiostar Advanced 2-Way Alarm System is suitable for all car makes.
Here's a list of car models that we have installed and the list is growing everyday!
In alphabetical order:
BMW
E36
Chevrolet
Aveo
Honda
Accord
Civic
CRX
Integra
Jazz
Kia
Picanto
Spectra
Mazda...
