DIY- Proton Gen 2 Rear Light Bulbs Replacement
ayen_s
25
40
1,513
Work: Change Rear Light Bulbs
Tool:
1. Philips Screwdriver - 1 unit
2.Multimeter - 1 unit
3. Replacement bulb - as required
Steps:
1. Open up your car boot.
2. Remove the 2 screw at the rear light using philips screw driver
3. Remove the nut inside the car boot by hand.
4. Pull gently the light towards you. Note the locking snub on the right.
5. Remove the bulb socket from its slot by twisting it counter clock wise
6. Replace the burned bulb with a new one.
Note you can check the continuity of the bulb terminal to ensure the bulb is faulty. No continuity means the filament is broken.
The replacement can be found at any auto accessory or spare part shop on the cheap. Bring along the defective bulb and show them if you not sure what to get.
7. Put back the bulb socket into the slot and lock it by twist it clock wise.
8. Reverse the steps to put it back.
Additional information if you need to trouble shoot:
Wiring Colour Code:
Black - Common (ground)
Red/Blue- Reverse indicator
Green/Black - Signal indicator
Green/White - Red light
Green - Brake light indicator
Note: 12Vdc will be supply through this connection if respecting indicator is activated.
Socket connection position
Visit my blog for more proton Gen 2 DIY. http://pimpmygen2.blogspot.com/
---------- Post added at 04:26 PM ---------- 6 hour anti-bump limit - Previous post was at 04:20 PM ----------
If you do not have somebody to press the brake and check the brake light simultaneously, you can do copy what i did in this picture.
the yellow gadget is my steering lock. I just jam it between my seat and brake pedal.
Booze
155
My bed room "on da BED"
www.defcon.org
This is very helpful
thanks
Just wanna share with you guys my experience of an axshole paint workshop. :mad::mad::mad:
MK Car spray specialist
Lot 264, Jln Cheras Perdana, Batu 10
Cheras.
It is a workshop own by a chinese(MR CHEW) and a myanmar guy.
I painted my whole car there. Reasonable price but not perfect service laa.
After few months, my front bumper cracked and had some scratch because a minor accident. Went back to the workshop, was quoted RM180 by the myanmar boss for the repair and whole...
