question about weber carb and 4 throttle
b8t_ford
294
hi guys, wanna to know about what is weber carb and what is 4 throttle?
i tot both things is the same just the name tak sama oli, but my fren told me that i am wrong. is not same.
so, nid to ask expert here about this. just wan to make it clear about this two things. pls give me more info about this. thanks 1st to u all.
SkYwAlKeR
10,139
300
ePoh ~ malacca
4 throttle is usually for efi engines... means each cylinder has its own intake system....
weber carb is a carburettor... there are other brand as well such as solex carb, mikuni carb, and aisan carb (4g13/4g15 oem carburettor)
some might relate a twin carb as something similar to 4 throttle for carbie engine...
b8t_ford
294
ooo ...i see.
then if i wanna to mod weber carb into fuel injection engine. then my ECU nid to do modification also ? because weber carb is cheaper than 4 throttle ma, hehe.
actually i m interested to put weber carb into my old car but i less knowledge in this area. so nid to do survey and ask ask all sifu here about thier experience.
as i know that, my car's engine have two important sensor which is air flow sensor and throttle sensor. then question is if i put weber carb fix into my engine, izzit very hard to start engine or hard to tunning also ?
anyone experience b4? i nid this info seriously.cos goin to mod. hehe.
thanks sifu sifu here 1st
SkYwAlKeR
10,139
300
ePoh ~ malacca
if change to weber carb, means convert ur car from efi to carburettor lor... ecu no need do adjustment, jz throw it away.... it is much more simple convert from efi to carbie...
but be reminded, twin carb fc gonna be heavy....
for more info about weber carb, join us at http://www.carbforum.cjb.net/
unknown1x
369
yep.. if you wants to save youer fuel.. 4 throttle is ways a better choice since you are using efi now.. or just simple mod,noneed change to carb nor 4 throttle, get a piggybag computer then good enouigh already.. for the starts.
well efi usees computer to tune the a/f ration.. and.. webber uses.. your hand.. hahaha
if you wants to mod.. best is to let everyone knows about your ride / budget and what are the things you looking for.. then.. i believe there alot of sifoos here ready to give you more answers.. as from noobie like me... i would recommend
get a piggybag , then later change to 4 throttle if you can afford it, its easier compare to changing a webber in overall as..
1) performance carb its harder to find
2) carb tuning vs efi tuning, you using efi.. so.. its more easier if you remain efi
3) FC wise... efi car is better, and twin dcoe makan petrol
mokomoko
895
154
dude, 4 throttle also makan petrol kau kau
remember the golden rule: more power = more fuel
If you get a 4throttle you will have to obtain a piggyback computer cause of the massive air/fuel ration.
theorekz
898
hiztorikal.c.t.
i think the 4 throttle u mean is twin dcoe eh?? most ppl refer twin dcoe as 4 throttle.... which ITB engine has good fc? i think i never see 1.. hehe..
unknown1x
369
theorekz, well thats a common mistake...
4 throttle =x= twin dcoe
well.. typically our engine inline 4 - so.. we have.. 4 cylinder, our stock one for carb 1.. 1 aisan carb... to manifold which split to 4 - thats why look like octopus ..
as for efi.. its 1 throttle, then.. also split to 4, so you see 4 lines something like that for the manifold for efi engine...
well.. in terms of concept of twin dcoe vs 4 throttle.. ..
dcoe got 2 lubang in and out, so.. its like... each dcoe pump to 2 cylinder..
while 4 throttle is.. each cylinder have their own throttlebody..
besides.. dcoe(webber) is carburator! and.. carburator.. dont need any ecu nor whatever computer chip.. its OLD SKOOL! but ROCKS! macam muscle car.. brutalforce.. mechanic tuning.. compare to...
4 throttle is efi, need ecu to tune. if you needf fit in one.have to get some safc or something i am not really sure (piggybag) to send to shop dyno and tune it for best effectiveness.. and.. you see toyota levin.. some have such setting.. more modern technologies..
if you wan see 4 throttle body engine.. go cari around this forum.. think have picture.. or.. go find chop shop.. visit visit.. sure can see one.. usually i see them in much of toyota levin.
theorekz
898
hiztorikal.c.t.
haha.... i think u havent come across mech that says dcoe is 4 throttle.... u r right.. most ppl mistaken about that.. btw, the correct term for 4 throttle on toyota 4age is called "individual throttle body".. it can definitely more than 4.... and whether dcoe pumps 2 cylinder o not is depends on ur setting.... if 1 dcoe splits into a intake manifold with 6 outlets... i think it pumps more than 2 cylinder in ur engine... it runs on 2 venturi per dcoe... just like the dcnf...
in fact, twin dcoes can be considered as individual carb too as u can set each trumpet on the dcoe running on different a/f ratio n jetting... thus it is not easy to fine tune a dcoe... too many jets to be considered.. if u have 2 dcoe on a 4 pistons engine, u can call it the old-skool ITB.... this is how the itb is born... all from the concept of dcoe..
and is 'weber' not 'webber'..... :)
pcdr
48
lovely lovely
but wait till u try 4throttle wit secondary injectors for each cylinder.....wet ur pants for sure,i did wet my pants.....but lets not talk bout that
SkYwAlKeR
10,139
300
ePoh ~ malacca
pcdr said:
lovely lovely
secondary injectors means bigger injectors??...
jombiee
950
13
Ghombau
sky, its additional injector loh.
hey, dont forget the fuel injection kit for weber ha ha ! cost a bomb though.
unknown1x
369
lol. sorry for my spelling error lah.. finger moves faster then brain.. lol
anyway. just curious about what you plan to mod? on what car/engine? for track use ar? or daily use. -__-
the thread starter macam sudah hilang only. hahah
leftfoot
287
.....and its 'piggyback', not 'piggybag'
b8t_ford
294
oooh.....i see ...
Thanks and terima kasih to all sifus here ......really thank you .
actually the story is like this, my family own a car , hyudai elentra year93 one. but recently, i found out that it hard to start and the ideling is not good, always up n down. then i drove it to workshop to check oredi lastmonth. formans said the throttle body is kong ady. nid to replace one. but the price is very expensive lor. then my dad ask me whether have others way to repair or not. then, i did many research wheter in workshop or internet(ZTH), then found out that now that throttle is rosak ady, then y don i put 4 throttle to increase my car engine performance lor. hehe ..........(gatal ma ).
then, now nid to ask ask all the sifus here lor . my car engine is almost same like vr4 or gsr one. mouting, intake all almost same.
now the questions are:
1. wat is piggyback ?hehe(i m newbie ah), izzit like mircotech or something similiar car management?
2. i donno the cost to do this modification la.cost of 4 throttle?mod tapak? agak agak how much ah ?
3. the cost of the piggyback is how much? lowest to highest ?
4. if i mod 4 throttle to engine oredi, i don wan use piggyabck ecu , is tat possible ?reason is very leceh oh, if can use back ori ecu, then is better la. if canot then i have to change it lor. hehe ..
5. wat other modification i nid to do after i mod 4 throtlle? like fuel pump? injector? intake maniford? or extra things? reason is, i nid to count my budget for others expenceses ma.
6.how many percent the FC will increase after set up 4 throttle? and also weber?
anyone experienced b4 ? can let me know ? thanks. cos nid to consider the fc also ma ....hehe
7. do all the sifu here know the best workshop in kl/pj area for doing 4 throttle?erm...i mean expert in mod 4 throttle la. hehe. if have,can rekemen to me ? thanks.
erm .....temporaly is that all . erm ....i say thanks 1st to u all la.all the best to u all .[/QUOTE]
SkYwAlKeR
10,139
300
ePoh ~ malacca
although i still noob, i try answer u few questions la...
1. piggyback is installed with ur oem ecu... some sort of extra program to improve ur current ecu.... it is usually pre-tuned by aftermarket manufacturers....
2. cost about rm2k to rm3k.... 4throttle is expensive... usually includes custom manifold...
3. no idea how much is a piggyback... depends on what brand as well...
4. if mod to 4throttle, alot of fuel+air will enter.... ur oem ecu cannot support such high performance... plus, oem ecu cannot be retuned.... it is advisible to get standalone ecu....
5. no idea... need to ask sifoo sifoo around...
6. percentage depends on ur right foot... everyday full throttle sure makan minyak lah.... but i'm sure gonna be worse than ur current FC now....
7. no idea... i not from KL/selangor area....
jz my 2 cents... if wrong correct me ya....
A vehicle based on the Chevrolet Beat concept, which swept through auto shows around the globe and the Internet earlier this year, will go into global production, Chevrolet announced today at the 2007 Los Angeles Auto Show.
An online poll that attracted more than 1.8 million voters helped influence the decision to take the concept to production. The distinctly styled A-class car will be initially targeted to markets outside of U.S. and Canada, starting in mid-2009.
“The people have...
