D.I.Y Cold Air Intake & Water Injection for Carburetor
Kendconcerto
271
A high grade Tupperware
Measure the K&N filter size, make sure it fit
Use Spray paint to mark the shape pattern of the carburetor base
Base pattern marked
Use fire to heat up a nail to cut the shape of the carburetor base on the tupperware (Using heat to penetrate n cut)
Cut the shape out
Kendconcerto
271
Shape cut out.....
Use water n sand paper to sand the uneven surface
Use masking tape to creat a *gasket* for the CAI box (to prevent loosening in long term)
A completed job of *gasket*
Fits on the Carburetor...
Kendconcerto
271
Make additional holes on opposite far end to drain unwanted water during raining storms
Cut a hole on the lid of the tupperware, add a funnel. Measure it so the funnel will face the right position
upward to your scoop.
Measure n mark the size of the hole for your CAI funnel
A close up of the funnel inside the scoop....
Find a suitable scoop, and you have a American Muscle Car style CAI ! (Engine roars sounds good too!)
Kendconcerto
271
Kendconcerto
271
*Water Tank* located under the funnel...
A small round tupperware as *Water Tank* (Side wall and lids are filled with 2mm holes
for Water Evaporate system (Simmilair to Water Injection System)
Pour 50% water to fill up the *Water Tank* Now you've got denser air mixture......
Total Cost:
1. Big tupperware------ RM7
2. Small tupperware--- RM2
3. Scoop --------------- RM35
4. Korek Lubang--------RM15 (Done at accesories shop)
5. DIY-------------------Priceless
What you get is a 1300cc engine that flies 160kmh-170kmh non-stop for 3 hours YET your temperature is at NORMAL tempt.
After maximum speed, the engine STILL pushing foward with G force, the only resistant is Wind Drag........I believe making 200kmh with proper aero dynamics is NOT a problem for a 1300cc......
Well, all these are JUST my opinion n R&D. My test results.... :)
Regards
Kendconcerto
271
ethanphoon592 said:
Won't your tupperware material soften once you kena the heat??
I must be at least wiser to buy tupperware that is High-Heat , dont I ? :angel_smile:
donCityZ
2,230
33
Waa... thumbs up for this DIY.
A true DIY idea and executed exactly according to plan.
Nice work!
I'm driving a 4g13p, budget RM 100 (RM 150 max). I don't know which to choose. I saw there are 2 type, the other type look like muffler. Go for which? the one look like muffler or the thinner one? :unsure:
