D.I.Y Cold Air Intake & Water Injection for Carburetor
Kendconcerto
271
A high grade Tupperware
Measure the K&N filter size, make sure it fit
Use Spray paint to mark the shape pattern of the carburetor base
Base pattern marked
Use fire to heat up a nail to cut the shape of the carburetor base on the tupperware (Using heat to penetrate n cut)
Cut the shape out
Kendconcerto
271
Shape cut out.....
Use water n sand paper to sand the uneven surface
Use masking tape to creat a *gasket* for the CAI box (to prevent loosening in long term)
A completed job of *gasket*
Fits on the Carburetor...
Kendconcerto
271
Make additional holes on opposite far end to drain unwanted water during raining storms
Cut a hole on the lid of the tupperware, add a funnel. Measure it so the funnel will face the right position
upward to your scoop.
Measure n mark the size of the hole for your CAI funnel
A close up of the funnel inside the scoop....
Find a suitable scoop, and you have a American Muscle Car style CAI ! (Engine roars sounds good too!)
Kendconcerto
271
Kendconcerto
271
*Water Tank* located under the funnel...
A small round tupperware as *Water Tank* (Side wall and lids are filled with 2mm holes
for Water Evaporate system (Simmilair to Water Injection System)
Pour 50% water to fill up the *Water Tank* Now you've got denser air mixture......
Total Cost:
1. Big tupperware------ RM7
2. Small tupperware--- RM2
3. Scoop --------------- RM35
4. Korek Lubang--------RM15 (Done at accesories shop)
5. DIY-------------------Priceless
What you get is a 1300cc engine that flies 160kmh-170kmh non-stop for 3 hours YET your temperature is at NORMAL tempt.
After maximum speed, the engine STILL pushing foward with G force, the only resistant is Wind Drag........I believe making 200kmh with proper aero dynamics is NOT a problem for a 1300cc......
Well, all these are JUST my opinion n R&D. My test results.... :)
Regards
Kendconcerto
271
ethanphoon592 said:
Won't your tupperware material soften once you kena the heat??
I must be at least wiser to buy tupperware that is High-Heat , dont I ? :angel_smile:
donCityZ
2,230
33
Waa... thumbs up for this DIY.
A true DIY idea and executed exactly according to plan.
Nice work!
Hello,
Bought Engine (lantai) SR20 manual Turbo from S14 car. After successfully installed on another car, found problems as follows;
1) When we took off the sump pan, there were small pieces of broken something about 2 table spoons worth-like when you smash a ceramic cup- the pieces are very small about the size of broken buttons.
2) Turbo made noise
3) The scary one- engine oil won't circulate, mechanic cannot see engine oil when oil cap removed.
the mechanic stopped work...
