Upsizing brakes in Nissan Sylphy
ixeo
4,788
3,080
KL, Malaysia
Hehe, only the Skyline GT-R R32 is called Godzilla.
The first GT-Rs were produced from 1969–1973. After a 16 year hiatus since the KPGC110 in 1972, the GT-R name was revived in 1989 with the Skyline R32. This car was nicknamed "Godzilla" by the Australian motoring publication Wheels in its July 1989 edition.
Well for the record Godzillas brakes is messing with my ABS. Need to figure out a way to work around this
How come?
The sensor detects the toothed pattern on the driveshaft right?
Nothing to do with whatever brake u installed.
Or,yours is different...
How come?
I'm not entirely sure what the problem is. I'm going to need to find some time this week to dismantle the whole jimbang thing.
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
After Izso told me on Sunday morning I then figure out what he was trying to tell me after thinking. The bolt he is looking for is called a Banjo fitting. Refer to picture below. It is usually used on caliper and hydraulic fittings. The Banjo fitting comes with 2 cooper crush washer.
Izso, I have this website which sell these fittings and usually it's hard to find on Malaysia website. This company they do international shipping or you can try to go find those shop dealing in hydraulic. They might have them.
Banjo Bolts and Brake Hose Bolts
This is the list of local shops dealing in hydraulics.
http://panpages.my/categories/my10843-hose-couplings-fittings/listings
New problem.
ABS keeps triggering even when I'm not heavy braking. Any ideas how to resolve this? I've tried a few things already and it's annoying like hell.
yewly1990
156
28
Hi all.
I've sort of successfully transplanted a 4-pot Nissan caliper taken off a R32 Skyline into my Sylphy. The only problems I have now :
1. I can't find a decently priced service kit. Anyone have? RM300+ for rubber seals is unreasonable.
2. The brake oil bolt that locks the brake hose to the caliper for the Sylphy is too long. I had to use spacers and washers to lock it out and prevent leakage. After asking 2-3 spare parts shops they aren't sure if they'll be able to source a shorter but similar bolt. Does anyone know where I can find a shorter bolt that has the hole in the middle to allow brake fluid through, 0.25mm thread and shorter than 3/4 inch long?
Any feedback, help or offers to sell will be appreciated. But if you have something to sell please PM, don't advertise here.
Did you try go to mechanical shop and custom one bolt? When I upsizing brakes, my bolt are custom also.
New problem.
ABS triggers when wheels are locked, could means your brakes are biting too well....:hmmmm:
peterj
1,321
258
1,683
Kuching
check my previous abs thread mr.izso.... u might find clue from there... try check for abs ring damages..if abs no damage check for dirt stuck on sensors... did your abs check light on?
My car is currently a 4G92 1.6 SOHC.
Im looking in to upgrading this bugger a little to give a bit more kick.
Is it possible to change my 4G92 1.6 SOHC top block to a 4G92 DOHC 1.6 MIVEC top block, Reuse my bottom block and gearbox, change the TB, intake manifold, ECU, exhaust manifold, and injectors to MIVEC ones?
Btw, how much does a MIVEC 1.6 top block with all other items (ECU, TB, manifolds, etc) cost nowadays?
