I am considering to replace my rear drum brakes on my 04 wira se with discs.... what are the recomended halfcuts that i should source..... a friend suggested i go for the evo 3 ones.... are there any other alternatives ?? tq
Well..i would suggest a sgti,mivec,putra or lancer@wira [email protected] one bcoz e size r e same..
Plus no need to change ur pcd on e knuckles bro..wira is pcd 100 while evo is 114.3..its a dimension in mm for cross lugs..
the engine off timer wire is connect to ignition switch & handbrake switch, how about the o2 & a/f, is it connect near to the ecu??? it will hv some problem or not??? and how about voltage connect to which wire???
