how to improve the performance of 4G13 stock engine
dakwan5555
13
1,503
1st stage - pnp head, camshaft and adjustable cam pulley... any aftermarket brand will do, alloy crankpulley any brand, extractor, 8" flywheel + clutch n clutch cover.
2nd stage - 4g15 block and internal, Fuel Injection set, upgraded front disk brake, rear disk brake, double layer servo.
3rd stage - 4g18/s4ph crank, oversize piston, engine management/piggyback etc, steel braided brake hose, Alloy radiator + fan + fan shroud.
ehdrian
I Don't Care!
3,310
280
1,683
4g15 can use 4g18 crank???...
Probably not. But what most people do is use the campro one. *ahem cough secret cough ahem*
Shinjite
864
120
Klang
4G13 mods, best bang for buck is to better jump to 4G15 block and start from there~~
If want to maintain 1.3L and see how far it can go, saw a lot of 4G13 dynoed around 75whp to 80whp range NA :)
thanks to all for giving info..
if i change to 1.5 block..is there any complicated procedure?need to endorse?
how about the cost?
Price depends on your luck on getting a cheap and cheerful block.
Legal procedure : do your swap, go Puspakom for inspection, go JPJ to update car registration card with new block number.
Illegal procedure : do your swap, keep quiet, don't get into accident. :biggrin:
Oh ya.. when buying the block make sure it comes with the grant. If not you will have a hard time registering it.
S16
64
508
as i done my research on it earlier, its very hard to get only the block, even if they have it without the grant. "Engine kosong" probably will cost around 1.2k (block + head)...
This is what I have done to my 4g13... Done it when fully rebuilt my engine
-Over-sized pistons (74mm)
-Bigger clutch (1.6)
-Bigger bearings
-1.6 throttle body
-exhaust system (4-2-1, mid bullet, s-flow(gti style)
2nd gear can reach 70km/h at 5krpm
3rd gear 110km/h plus...
hope this info helps you bro... :)
pearl24
Jan 29, 2012
5
sabah
-Bigger bearings
-1.6 throttle body
bro..
how about gear 3 reach 140kmj..,gear 4 160kmj..,
S16
64
508
4th gear till 140... and settle down at 150km/h at 5th gear... :)
dakwan5555
13
1,503
4g18 is code for waja 1.6 engine and get the 1st model one bro :)
---------- Post added at 04:31 AM ---------- 6 hour anti-bump limit - Previous post was at 04:21 AM ----------
For s4ph crank, don't forget to grind the bottom end (for crank/conrod clearance)of the block and full engine balancing too.. :driver:
azharzawawi
5
thanks S16 for the info..
does it means that i have to rebore my block to fit the 74mm piston?
waa...really newbie laa bro...huhuhu:banghead:
S16
64
508
I myself still on learning process bro... yup, ur block need to be rebored... If your budget allow, go for 1.5 block as u wont regret for it... can use 78mm oversized pistons with 4g15 block... :)
---------- Post added at 11:06 AM ---------- 6 hour anti-bump limit - Previous post was at 11:04 AM ----------
if u wanna get more info about fitting 4g18 crank shaft on 4g15, can try PM khguan...
kanthang
23
1,503
helo everyone. i have a 4g15 engine which has just failed jpj inspection. Whats best way around getting the engine back in order to pass the inspection? It failed because they claimed that engine no was tampered with. So far, I know 2 options:
1) Change the whole engine - RM3k (include labor)
2) Change the block - below RM1k(cheaper but labor will be expensive and jpj endorsement will be tedious.)
Anyone with suggestions, i would really appreciate it
ixeo
4,788
3,080
KL, Malaysia
Go straight to a 4G93 block.. still within 30% allowance..
I can go on and on about how the world doesn’t need SUV’s, and I still believe we don’t. I’ve made up my mind, there’s no changing it. The fact that they kill people in normal cars while the occupants of the SUV walk away is selfish. Manufacturers should be making cars to save everybody because cars exist in our world, they should be protecting us, not kill us. The idea is to make cars safer, not make them bigger...
