how to improve the performance of 4G13 stock engine
dakwan5555
13
1,503
1st stage - pnp head, camshaft and adjustable cam pulley... any aftermarket brand will do, alloy crankpulley any brand, extractor, 8" flywheel + clutch n clutch cover.
2nd stage - 4g15 block and internal, Fuel Injection set, upgraded front disk brake, rear disk brake, double layer servo.
3rd stage - 4g18/s4ph crank, oversize piston, engine management/piggyback etc, steel braided brake hose, Alloy radiator + fan + fan shroud.
ehdrian
I Don't Care!
3,310
280
1,683
Penang
4g15 can use 4g18 crank???...
Probably not. But what most people do is use the campro one. *ahem cough secret cough ahem*
Shinjite
864
120
1,543
Klang
4G13 mods, best bang for buck is to better jump to 4G15 block and start from there~~
If want to maintain 1.3L and see how far it can go, saw a lot of 4G13 dynoed around 75whp to 80whp range NA :)
thanks to all for giving info..
if i change to 1.5 block..is there any complicated procedure?need to endorse?
how about the cost?
Price depends on your luck on getting a cheap and cheerful block.
Legal procedure : do your swap, go Puspakom for inspection, go JPJ to update car registration card with new block number.
Illegal procedure : do your swap, keep quiet, don't get into accident. :biggrin:
Oh ya.. when buying the block make sure it comes with the grant. If not you will have a hard time registering it.
S16
64
508
Melaka
as i done my research on it earlier, its very hard to get only the block, even if they have it without the grant. "Engine kosong" probably will cost around 1.2k (block + head)...
This is what I have done to my 4g13... Done it when fully rebuilt my engine
-Over-sized pistons (74mm)
-Bigger clutch (1.6)
-Bigger bearings
-1.6 throttle body
-exhaust system (4-2-1, mid bullet, s-flow(gti style)
2nd gear can reach 70km/h at 5krpm
3rd gear 110km/h plus...
hope this info helps you bro... :)
pearl24
Jan 29, 2012
5
sabah
-Bigger bearings
-1.6 throttle body
bro..
how about gear 3 reach 140kmj..,gear 4 160kmj..,
S16
64
508
Melaka
4th gear till 140... and settle down at 150km/h at 5th gear... :)
The Marketplace Top Posts
Guys,
i wanted 2 setup car wash sumwhere in klang valley. but d worst thing is, i dun hav any experiance at all. so i've post dis thread so dat u guys can guide, help, gimme input n advice me wut should i do.
btw, there is any places dat potentially location 4 car wash sum where in klang valley?
i hope u guys can help me!
thx 4 ur time!
cheers!
:nurse:
