Re: which piggyback Is the most BEST for vehincle ??
what kind of engine ur fren using?
of course e-mane much more better than AFC!!! But double price leh!!!
Some more AFC have digital display...quite shock sometimes!!!
emanage
- allows u to tune fuel mapping and ignition timing (give u have the required harnesses)
- needs laptop+software as tuning interface (u need the usb-usb cable as well)
safc
- only allows fuel mapping manipulations
- does not need any other interface/software... jz wire it up and tune ur car
Bump:
Lets talk about something more affordable la.
How about substituting the entire ECU, some same its much better than using piggy back?
substituting the entire ecu means u are using standalone ecu.... standalone ecu cost much more than any high end piggyback ecu... usually not cheaper than rm5k....
advantages of using standalone ecu, u able to reprogram the whole system and fine tuning each n every part of ur engine...
for example, converting ur efi engine with single throttle body to individual throttle body mostly requires a standalone ecu as it allows more precise tuning of fuel mapping....
