putting catalytic converter near rear muffler
VectorX2
268
45
528
hi guys,
what is the effect of putting the catalytic converter all the way near the rear muffler? is it a huge power loss? will the catalytic converter still work?
crazykatak
776
48
Subang Jaya
the cat con operates at a certain temperature range only. any lower or higher, then it is no use.
Temperature range is between 600-700 degrees C.
and mind you, the honeycomb construction causes restriction to the exhaust flow; like putting thick cotton wool in your nostrils when you're trying to breathe out..difficult aye ? :)
Veloc
3,234
991
Sabah
If you really want the cat con to work, put is as close as possible to the manifold. It needs to be hot to work.
---------- Post added at 03:44 PM ---------- 6 hour anti-bump limit - Previous post was at 03:44 PM ----------
nope..dun worry too much bout the cat con...it wont work after 2-3 yrs......
Bro seriously? Cat cont lifespan so short? Not even 5-7 years?
Fingers crossed, prayers said and all deeds with the devil signed, let’s hope this time around it isn’t pushed back yet again as a post on Playstation Blog has confirmed that Gran Turismo 5 will be going on sale 24 November.
Sarcasm aside though, even we of little faith have some believe that this time it’s for real as Kazunori Yamauchi, the president of Polyphony Digital, has explained the delay in a...
