putting catalytic converter near rear muffler
VectorX2
268
45
hi guys,
what is the effect of putting the catalytic converter all the way near the rear muffler? is it a huge power loss? will the catalytic converter still work?
crazykatak
776
48
Subang Jaya
the cat con operates at a certain temperature range only. any lower or higher, then it is no use.
Temperature range is between 600-700 degrees C.
and mind you, the honeycomb construction causes restriction to the exhaust flow; like putting thick cotton wool in your nostrils when you're trying to breathe out..difficult aye ? :)
Veloc
3,234
991
Sabah
If you really want the cat con to work, put is as close as possible to the manifold. It needs to be hot to work.
---------- Post added at 03:44 PM ---------- 6 hour anti-bump limit - Previous post was at 03:44 PM ----------
nope..dun worry too much bout the cat con...it wont work after 2-3 yrs......
Bro seriously? Cat cont lifespan so short? Not even 5-7 years?
I'm new here and i just got my new car (2nd hand). Only to found out after got home. The rain stain/tear will be visible when the car in shade and outside is bright sunlight then i'll see all the wind screen , window and rear screen all have rain stain/tears.
I know that by using Rain X i should be able to remove some of those stubborn stain but i just don't want to spoil my wiper blade. Which is what i was told that Rain X will make the wiper blade harden faster...not too sure about...
