putting catalytic converter near rear muffler
VectorX2
268
45
528
hi guys,
what is the effect of putting the catalytic converter all the way near the rear muffler? is it a huge power loss? will the catalytic converter still work?
crazykatak
776
48
Subang Jaya
the cat con operates at a certain temperature range only. any lower or higher, then it is no use.
Temperature range is between 600-700 degrees C.
and mind you, the honeycomb construction causes restriction to the exhaust flow; like putting thick cotton wool in your nostrils when you're trying to breathe out..difficult aye ? :)
Veloc
3,234
991
Sabah
If you really want the cat con to work, put is as close as possible to the manifold. It needs to be hot to work.
---------- Post added at 03:44 PM ---------- 6 hour anti-bump limit - Previous post was at 03:44 PM ----------
nope..dun worry too much bout the cat con...it wont work after 2-3 yrs......
Bro seriously? Cat cont lifespan so short? Not even 5-7 years?
hi there.........sifus,need to ask stuffs.....i came across these Mine's Adjustables at a very good price.The seller claims it's under Gab licensing......are they fakes or did they really came up with these new adjustables?
