Puspakom inspection with iswara ori loud muffer
badguy
951
Puspakom with abosrbar "uk uk uk" sound and gold tinted
i m going to puspakom for inspection tomorrow
the rear absorbar got this "uk uk uk" sound and wind screen gold colour
will the Puspakom inspector fail me??
how can i give him a drink kopi??? how ??
pls help me!
acbc
4,615
KD
Like that ar? Fail lor...
Kopi? Good luck man... don't let ACA go after u.
badguy
951
help really canno pass ah??????
any one got pass with loud muffer???
Duke Red
2,023
Earth
to my understanding if it's not factory fitted, it's illegal. it's ok for iswara's to have them as they were fitted in the factory and all stock iswara's come with them now. stock wira's don't. hence i think the best thing to do would be to 'rent' a stock exhaust from a workshop and just go for inspection. habis inspection, change back lah.
badguy
951
in the begining i also think it is original should be ok
but after i convert engine to 4G91 then i now scare to go for puspakom inspection
if they kacau say cannot then fail me then i have to go second time is it??
don't have so much time to do that leh!
saturday puspakom got open or not?
gsrTurbo9166
958
bro how come u woli about the 4G91?wat is ur ori car cc???
nowaday JPJ will pass u if ur car is according to the law(25% increase)
last time i go 4 inspection 4 my 4G93t with loud muffler n it is ok to them
sam1741
1,188
wah.. u use 4g91..
but .. u use exhaust muffler that fitted for 1300cc car?
i a bit confused...
huakenny
LB Performance
9,126
240
Kota Kinabalu
ori iswara se muffler wil failed if fit into wira...take one gun n shoo them lo
same engine n same muffler...juz put in differ car...if failed...nothing to say la
they wil tell u Iswa punya original...lu punya wira bukan original...lu pasang sendiri...... :albertein
pdj2827
103
Heaven
my satria 1.6 now using 1.8 putra engine with 2inch 4-2-1 extractor and connect back the 1.6 cat and muffler. if i rev sound quite loud and quite weird sound la.. will puspakom fail me as well?
badguy
951
tomorrow going to puspakom
now new problem
my rear absorbar with "kuk kuk ku" sound how???
and my tinted donno how many percent also (gold colour not very dark lah)
will the puspakom fail me ???
very headatche lah
badguy
951
help.......
any one pass with absorbar got sound?
AccordRacing
2,282
kepong
www.zhapalang.com.my
wat is ur car model,if wira Rr got "uk Uk uk" sound coming out mostly is the lower arm problem,about drink "kopi",i think u can ez get those runner around puspakom ^^
badguy
951
how i give kopi my self?
and with the uk uk uk sound will the inspector fail me or not??
partyJOE
2,221
dont use runner lar... if inspector charge u 50 runner will sapu u 100...
just be frend with the inspector first...just talk talk first...
different inspection section differnt inspector u know...
he wont fail u for 'kek kerk' sound... only for faulty parts n functions...
pls pay attention cos suspension is one of their highest priority...
u need passing mark 4 dat... go home... jackup yr car...n spray wd40 at the join area to reduce the noise... it all depends on yr luck man.... gud luck 2 u...
AccordRacing
2,282
kepong
yup,those machine cant found those sound just depends the inspector mood only,but normally will fail allignment so better do it 1st,2nd ask car wash to wash bottom part and spray black oil on it,to cover oil leak,some more adjust brake also
badguy
951
partyjoe that means i can talk to each inspector also is it true??
but according lampakia i will need to leave my car for them to kau tiam them self ?
badguy
951
alignment also will check ah??
very hard lah my rear alignment will need to add thing to get it back to normal
now is -1.1 leh
how???
really will check??
my front alignment is in order
AccordRacing
2,282
kepong
urs company car or private car,if private then just let those "lampakia" settle it,or else if the inspector make trouble with u and cause u reinspection few times the cost almost the same some more waste time to wait
halo guys,i wanna asking about the extractor (exhaust manifold)
i driving a satria 1.3 card,some people say a aftermarket performance extractor a part from 4-1 that piping,normal short is more better aftermarket long 1,cos gas run out to a point when 4 - 1 fast back pressure,aftermarket too long,back pressure to low respon.
which 1 right? izzit really truth just dun touch 4-1 part,just from 4 to 1 piping there weld it long more,got effect woh!!
if i wanna follow a size long normal 4-1...
