Car Shops and Services
Don't Fail Puspakom Again
SCS TEST SOLUTION
Sep 6, 2019
5
44
PASS YOUR PUSPAKOM INSPECTION TODAY!
So you’ve just done a full service & maintenance on your vehicle (car, van or lorry) but it still failed the Puspakom inspection and you don’t understand why (and it probably wasn't the first time too). Your vehicle is now grounded & you’re incurring the losses. Don’t despair, stop wasting time & money. Let us at SCS Test Solution determine the true cause of the failure, find solutions to fix it & with your approval, proceed to do the needed repairs & maintenance on it.
Your vehicle can definitely get that Puspakom Certificate the next time you go for your inspection appointment. Just TAP WhatsApp to make an appointment, ask your questions or you can visit us at our garage today, TAP LOCATION for the map. Don’t forget to bring along your report from Puspakom so that we can redo the tests that your vehicle had failed, identify the cause & fix it. If you’re still worried, we’d be more than happy to do more testing if you request it. See you soon!
#JOMTEST sampai pass, apa lagi risau!
SCS TEST SOLUTION
5
44
8 TIPS TO PASS YOUR PUSPAKOM
Brake Inspection
A brake test is part of the Inspection at Puspakom and these are a few tips on how your vehicle can pass the Brake Inspection.
If you want to be sure that your vehicle will pass the brake test, WhatsApp us now for an appointment or drop by SCS TEST SOLUTION and get your vehicle tested TODAY!
<iframe src="https://www.google.com/maps/embed?pb=!1m18!1m12!1m3!1d254982.12633057346!2d101.49126957370669!3d3.0690894941451057!2m3!1f0!2f0!3f0!3m2!1i1024!2i768!4f13.1!3m3!1m2!1s0x31cc35a65a1762a9:0x6181a4fbc32f7d8a!2sSCS Test Solution Sdn Bhd!5e0!3m2!1sen!2smy!4v1568773279114!5m2!1sen!2smy" width="600" height="450" frameborder="0" style="border:0;" allowfullscreen=""></iframe>
SCS TEST SOLUTION
5
44
Checked your tyre treads yet?
Tyres are important!
Your tyres are the only link between your vehicle & the road with a critical contact area no bigger than the palm of your hand. Aside from being a safe driver, good conditioned tyres are vital for safe driving.
4 Vital Functions of your tyre:-
  1. Acts as a shock absorber for vibration from the road
  2. Maintains steering and directional control
  3. Provides grip for braking and acceleration
  4. Supports the weight of your vehicle
What are tyre treads?
The grooved outer layer of your tyres is the Tread. It is the part of the tyre that is in direct contact with the road. The rubber compound is designed to grip the road, resist wear & tear, and cope with the high temperatures generated from friction. Sufficient tread is important to keep you, your loved ones & your cargo safe no matter the conditions.
Bridgestone has some great tips so tap on How to Check Your Tyre Tread Depth to leran more.
Want to test your car?
Whatsapp us now to ask your questions or come drop by our garage to do a quick test & consultation.
SCS TEST SOLUTION
5
44
5 TIPS TO PASS YOUR PUSPAKOM
SIDE-SLIP INSPECTION
Following the MOT Inspection Standards, Side-Slip testing is part of the Puspakom inspection list. So here are tips on how you can pass your Side-slip Inspection.
Stop worrying if your vehicle will pass or fail the side-slip inspection and Whatsapp us now for an appointment or drop by SCS TEST SOLUTION to get your vehicle tested TODAY!
Like & follow our Facebook Page to get more tips & keep updated about us!
#sideslipinspection #scstestsolution #scstest #failinspection #failpuspakom #luluspuspakom #gagalpuspakom #inspection #ehailing #grab #grabmalaysia #rakangrab #BeratSamaDipikul #mycar #dacsee #jomrides #ezcab #mula #ridingpink #lori3tan #thelorry #cubadulu #puspakom #janganfaillagi #malaysia #kualalumpur #selangor #cheras
SCS TEST SOLUTION
5
44
EMISSIONS INSPECTION
When we drive, we rarely notice the color of our exhaust fumes. The different colors actually show how efficient or inefficient your vehicle is burning fuel as well as if there is a bigger problem with your vehicle. Emissions testing is part of the Puspakom inspection list. So here are tips on how you can pass your Emissions Inspection.
Stop worrying if your vehicle will pass or fail the emissions inspection and Whatsapp us now for an appointment or drop by SCS TEST SOLUTION to get your vehicle tested TODAY!
#emissioninspection #smokeinspection #exhaustfumes #scstestsolution #scstest #failinspection #failpuspakom #luluspuspakom #gagalpuspakom #inspection #ehailing #grab #grabmalaysia #rakangrab #BeratSamaDipikul #mycar #dacsee #jomrides #ezcab #mula #ridingpink #lori3tan #thelorry #cubadulu #puspakom #janganfaillagi #malaysia #kualalumpur #selangor #cheras
Im driving a wira with converted engine and rear disc brake. It seems that they only assist less than 10% of the braking. The rear disc brake pads are rarely change, the disc looks smooth & there is no cove at the tip of the disc. means it has never really been use. i was hoping to get hand brake stop effect at 80km +, but mech says it not possible. any advice ??
