Need some advise from Airtrek Turbo
Cars
176
Hi all, I was thinking of to get a Airtrek Turbo. But before that i wish to know fews points as below. Hope able to get some advise.
- Fuel comsuption?
- High maintainece?
- Spare part available?
- Any problem with the turbo or gear box?
- Or some I might left out :hmmmm:
Thanks in advance :driver:
kampoon
1,205
89
1,648
Fuel comsuption?
20 - 30 cents / km
base on normal driving
- High maintainece?
so so lar...still a car just that more fluid to replace
4WD diffrencial oil
Yes...some can share with proton
should be normal as long as not crazy mod.
leslie
2,946
230
5,163
best if after purchase install an oil cooler for your gearbox.. to safeguard it... other than that.. i have a friend driving an airtrek for about 4 years.. not much problem.. just the normal wear and tear..
stutzedward
3,416
561
I own a 2003 Airtrek Turbo. So I can share my experience.
Fuel Consumption - In stock, it used to be around 7km/liter. After modification like increased boost, better plugs, air filter, straight flow exhaust and tweaking of ECU, I get about 5.7 to 6.3km/L. Also very dependable on your mood of driving.
Maintenance - Pretty normal like any other Evos. Engine oil change every 5-7K for fully sync and 15K for LSD (front and rear) and ATF.
Spare parts - No problem.
Turbo and gearbox - no problem if periodical oil change and like others said, oil cooler kit will be beneficial.
Cars
176
Thanks for sharing your experience bro ....
Hi guys !! I bought a pair of adjustable cam pulleys/gears and i need to know the best settings for 4G93p. Anyone knows about it?
