Folks , i just changed at rear left wheel bearings and change tires at the rear side to try to eliminate this wobble vibration which occur at 80-90km/h and after that speed, it will be gone ... The vibration can be felt through rear and front seats. After changing the tires at the back and the rear wheel bearing, the wobble is still there. The only left over cause i can think of is the one of the rims behind, which one of them is dented. The dented rim was previously repaired but i can still see there is still slight up and down while rotating on the balancing machine, my question is, can this slight dented rim cause the wobble i am having now ?
Note that i have the rim repaired at Tek Ming at Sunway ... Please give review of this shop so i can advise others to avoid them if they are really bad at doing such repairing ...
