Need Advice - 20VBT coughing carbon deposits
gilbert
75
To all toyota bro's, i notice my ride was coughing out carbon deposits through the exhaust early in the morning when i start it. Secondly, symptoms of engine oil decreasing was a also observed and i need to top it up like once a week. Just recently transplanted about two months back with e-manage. This issue has been bugging me for the past few weeks. Is this normal?
pcmoddingmy
1,147
101
www.pcmoddingmy.com
Looks like you need to overhaul already... must be revving the heck out of it yah? Hehe...
Well, suspect piston ring and valve seals worn out.
At the mean time, have you checked the spark plugs?
chinozie
Very Young Member... :D
3,429
170
5,163
Damansara
4age20v.blogsome.com
"coughing out carbon deposits" ...heee mine too...it's mainly because of old piping n muffler system...carbon filled up already, chocking the fiber inside it, perhaps...my engine on very healthy condition, newly rebuild 15k km olready... :D
Oil decreasing ? any white smoke during idling or high rev ? any oil leakage ? any engine overheat ?
gilbert
75
Okay, that seems to be a major issue. Din rev much though. Just sent for dyno 3 times and the result was this. Will try checking the spark plugs first as mentioned if nothing wrong means could be the valve seals and piston ring then. Dang, i hardly whack it that hard. Just occasional abuse i guess. By the way, there's white smoke coming out during cold start but after that it becomes normal.
---------- Post added at 04:58 PM ---------- 6 hour anti-bump limit - Previous post was at 04:55 PM ----------
On thing i forgot to mention, the piping was new so i guess that wouldn't be the culprit. No oil leakage and overheat. My biggest suspicion would be the valve seals and piston ring too. But hopefully that isn't true.
gilbert
75
Nah, it sounded normal though. How come yours sounded like diesel. Mind to elaborate what causing it ?
wilm3
500
29
20v = diesel engine ma...wakakaka...my bro-in-law asked me b4 is my corolla diesel?? hehehe..
YUZZRAY
138
KAJANG,SELANGOR
Yup.. sounds like diesel..but dont worry.. we already discuss this topic about a few weeks ago.. some sifu says this is normal for 20V engine.. they said maybe my VVT need to service... You can only hear the sound during engine idling..but after the padal is pumped..you know what i mean.. 20V screaming..!!you can search for my thread to read more.. just FYI..
hon_cs
251
43
3,028
Ipoh
oil topup once a week is consider quite serious. actually base on the symptom above, what you dont wish to happen is actually happened. bring it to mechanic is the best rather than guessing and make ur day down.
chuckie
508
23
faced this prob when i was using BT20V last time. No oil leaks at all. happens maybe due to piston ring or valve seal. will come worst if high rev. black smoke, comfirm. in high rev some more. some time fire cominf out from the exhaust. it's fun.... vtec prrrannngggggg bt pringgggg
To all the sifu out there....I need some suggestion, I have 2 engines on my mind now...either 4G91 DOHC or 1.6 V6 for my saga...
I need some comments and advice on which engine is better in performance and which engine is more reliable....
Can all the sifu give me some comments cause I really dont know which 1 is better...
