Mazda 3 Noise driving on uneven road
nicollim
Hi Guys, I owned a Mazda 3 2015, and when driving on the uneven road i hear noise, the knocking sound is like (small chinese muyus). I send back to my dealer (service centre) and they have me to replace lower arm bush, and the 2nd time they help to replace both bearing strut. But the noise is still there, usually when it is very quiet at indoor parking, over the bump or uneven surface, you will get it. Mazda want me to put my car there for 1 week which i cant, if someone encounter the same problem and solve can you please advise me what is the problem, or if you can recommend me a good mazda service centre, at least i dont have to keep sending my car and not getting it fix.
Please help!:banghead:
Could be number of things, like tie rod, steering column and coupling, the shock itself ... I would start checking on the shock itself, see whether it has any freeplay when shake it left or right.
Have you try to step on your brake during uneven road? if the noise gone It might be loosen caliper.
When driving, can you tell roughly where the sound is emitting from?
Could it be a faulty top mount?
never came across this symptom, are loosened calipers common?
Loose calipers are mostly due to the guide pin. I've all 4 brake calipers with loose guide pin because of wrong lubricant use ! It won't cause any long term damage but it severe enough, it will break. For that reason i modified my brake systems to fixed rather than floating system.
okay that's refreshing, I don't remember hearing such cases before. now I have something new to monitor
by the way, you mentioned wrong lubricant? Lubricant as in bolt grease?
Yes i meant bolt grease, for certain brands of brake pad, the manufacturer will provide a small bag of grease for your guide pin included in the box upon purchase. For my case, the mechanic used some multi purpose machinery grease to lubricate my guide pins when i wanted to replace my brake pads. The damn grease wear out so fast that damages the guide pin. Please please please make sure your mechanic uses the right grease for lubricating the guide pin. i don't want anybody meet the same thing like mine.
It could be happen if using wrong grease or never apply grease. The caliper pin might interact with the caliper and causes loosen over a certain of period.
Noise can be from all sorts of things, not easy to detect the root cause. Need to zoom in first from around which location, front/rear, left/right, middle, underneath, inside engine compartment or the boot, or where? Sound like metal, plastic, rubber, or what?
This is only about 1 year old car also, strange...
It could be a lemon product. If its less than 1 month, i would ask for a new replacement.
If floating guide pin you need the grease to keep it lubricated, but my mechanic uses rubber grease as not to damage the rubber seals. If use normal grease rubber seal will expand or break down with time. Been using rubber grease for many many years already. Method of just apply enough to lubricate. Don't over apply....:driver:
Agree, to find the exact place the noise is coming from needs to check thoroughly. Sometimes sound like from left but actually from the right. I had my fair share of searching for noise in 2 of my cars.....lol:biggrin:
Too late lol, i've modified the front with 4 piston sumitomo brake caliper. The rear still retains and now it rattles slightly. Going to source for a 2 pistons GTT caliper to pair with it. You got kang tao ?
Do you need so strong braking in the rears? Already have 4 pots in front.....:driver:
Have to check chop shop loh......
aaaaaaaaaaaaand the thread starter has disappeared.
In my personal opinion, until we physically see the car, everything we say will only be speculation.
How old is the Mazda 3? Which model? Was it ever in an accident? Which side is the sound coming from? Does it sound metallic or just a wooden thud noise? How to replicate the sound? Does it only happen on a certain type of road?
Eh i think i need to balance out the brake force distribution. When i do hard braking or any sudden brake, the rear part slides out a little. The skid is very manageable but somehow does not feel good if i am doing trail braking into corners. Furthermore the rear stock calipers now rattling alittle so its a good reason to mod :rofl:
Exactly, noise is the toughest thing to check on in a car.......:biggrin:
Rear slide could mean the rears locking before the front too. My VR does that, but my tyres are old and harden....:bawling:
Yeah thats could be it but i could not hear any tyre screeching sound though. I only did a little lift off oversteer through a corner because the rear brake was locked up and sliding action coming in. I lifted throttle and brake off then apply light throttle with neutral steer and pray not to hit the walls. In the end i've executed a lift off oversteer :stupid:. I need to mod the rear for more balance drive.
Back to the topic, tracking suspension noises are serious pain in the ass. TS has disappeared from this topic, guess he either found his solution or simply forgot to check back. In my advise, typical new car suspension's noise mostly are from the stock struts and shocks. Speaking from experience of coz.
That's because of weight transfer. If the front 4 pot is much harder braking but not yet locking/sliding, then the rear end lift up hence loose traction. If you want to do trail braking when entering a corner and since you're using automatic car, better use left foot braking then it can be more balanced as your right foot can still be on throttle to power out and neutralize the oversteer.
New Posts
