Mazda 3 Noise driving on uneven road
nicollim
Jan 5, 2015
9
Hi Guys, I owned a Mazda 3 2015, and when driving on the uneven road i hear noise, the knocking sound is like (small chinese muyus). I send back to my dealer (service centre) and they have me to replace lower arm bush, and the 2nd time they help to replace both bearing strut. But the noise is still there, usually when it is very quiet at indoor parking, over the bump or uneven surface, you will get it. Mazda want me to put my car there for 1 week which i cant, if someone encounter the same problem and solve can you please advise me what is the problem, or if you can recommend me a good mazda service centre, at least i dont have to keep sending my car and not getting it fix.
Please help!:banghead:
Mitevo7
1,456
179
Could be number of things, like tie rod, steering column and coupling, the shock itself ... I would start checking on the shock itself, see whether it has any freeplay when shake it left or right.
jerrysiow
407
146
Seremban
Have you try to step on your brake during uneven road? if the noise gone It might be loosen caliper.
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
When driving, can you tell roughly where the sound is emitting from?
Could it be a faulty top mount?
never came across this symptom, are loosened calipers common?
Mitevo7
1,456
179
Loose calipers are mostly due to the guide pin. I've all 4 brake calipers with loose guide pin because of wrong lubricant use ! It won't cause any long term damage but it severe enough, it will break. For that reason i modified my brake systems to fixed rather than floating system.
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
okay that's refreshing, I don't remember hearing such cases before. now I have something new to monitor
by the way, you mentioned wrong lubricant? Lubricant as in bolt grease?
Mitevo7
1,456
179
Yes i meant bolt grease, for certain brands of brake pad, the manufacturer will provide a small bag of grease for your guide pin included in the box upon purchase. For my case, the mechanic used some multi purpose machinery grease to lubricate my guide pins when i wanted to replace my brake pads. The damn grease wear out so fast that damages the guide pin. Please please please make sure your mechanic uses the right grease for lubricating the guide pin. i don't want anybody meet the same thing like mine.
jerrysiow
407
146
Seremban
It could be happen if using wrong grease or never apply grease. The caliper pin might interact with the caliper and causes loosen over a certain of period.
Noise can be from all sorts of things, not easy to detect the root cause. Need to zoom in first from around which location, front/rear, left/right, middle, underneath, inside engine compartment or the boot, or where? Sound like metal, plastic, rubber, or what?
This is only about 1 year old car also, strange...
Mitevo7
1,456
179
It could be a lemon product. If its less than 1 month, i would ask for a new replacement.
29,998
If floating guide pin you need the grease to keep it lubricated, but my mechanic uses rubber grease as not to damage the rubber seals. If use normal grease rubber seal will expand or break down with time. Been using rubber grease for many many years already. Method of just apply enough to lubricate. Don't over apply....:driver:
29,998
Agree, to find the exact place the noise is coming from needs to check thoroughly. Sometimes sound like from left but actually from the right. I had my fair share of searching for noise in 2 of my cars.....lol:biggrin:
Mitevo7
1,456
179
Too late lol, i've modified the front with 4 piston sumitomo brake caliper. The rear still retains and now it rattles slightly. Going to source for a 2 pistons GTT caliper to pair with it. You got kang tao ?
29,998
Do you need so strong braking in the rears? Already have 4 pots in front.....:driver:
Have to check chop shop loh......
aaaaaaaaaaaaand the thread starter has disappeared.
In my personal opinion, until we physically see the car, everything we say will only be speculation.
How old is the Mazda 3? Which model? Was it ever in an accident? Which side is the sound coming from? Does it sound metallic or just a wooden thud noise? How to replicate the sound? Does it only happen on a certain type of road?
Eibach sucks
Eibach pro kit for putra.
Front - 2 fingers.
Rear - 5 fingers.
Just after a week, the front started to give "ekkkk ekkkkkk" sound on the driver side whenever i pass through road bumps or uneven road. And what's more? The ABS light also blinks occasionally (wheel touching the ABS wire until it hurts). I went to tyre shop and asked them to put rubber. But the annoying sound is still there. Dunno whether the Monroe absorber already kong or not. But there's no sign of any...
