If use oil cooler, do I need to upgrade oil sump?
Sil80-13
1,215
44
1,648
Hi,
If I want to install an oil cooler, is it a must to upgrade my oil sump as well?
Sil80-13
1,215
44
1,648
Opps...Sorry. It's Oil Pump. But some ppl call it oil sump. Right? :biggrin:
Means upgrade to larger in order to install oil cooler. It's a MUST?
It won't hurt to have faster flowing oil since you're reducing the oil pressure by adding the cooler. But this is highly dependent on the type of cooler you're installing. If it's a small one and doesn't affect the pressure much then no need la. If you're gonna go bigass with the cooler then most likely a stronger oil pump would be useful
ken yeang
6,000 RPM
6,617
1,327
faster flow of oil is good, but moving bigger oil volume at a higher rate with upgrade oil pump will cause parasitic lose for the engine. You gain something, you lose something...
if we can gather 5 ppl, 10% discount that means
for 4G15 : 410-41 = 369
369 for 4G15 extractor
for 4G9X : U guys gotta calculate yourself
