E eye Junior Member Senior Member Jul 7, 2005 15 0 1,501 Butterworth Jul 10, 2005 #1 I was using 4G61T, due to recently my engine "tepek" always kacau n i think the hidurlic was damn, but my friend tell me that if i using disel lubricant i can slove the problem, is it work??
A acbc 4,000 RPM Senior Member Jan 9, 2004 4,615 8 3,138 KD Jul 10, 2005 #2 Actually, pls use 15W/50 oils... not lower esp for 4G6x engines. Reason? It is the recommended choice by Mitsubishi back in the 80s. If you rebuild the engine, then only use 15W/40 or lower. I'm using Motul Power 4000 15W/50, no tappet sound since Day 1 unless oil level is low.
