Oil sump is the place where oil sits wor.Opps...Sorry. It's Oil Pump. But some ppl call it oil sump. Right?
Means upgrade to larger in order to install oil cooler. It's a MUST?
It won't hurt to have faster flowing oil since you're reducing the oil pressure by adding the cooler. But this is highly dependent on the type of cooler you're installing. If it's a small one and doesn't affect the pressure much then no need la. If you're gonna go bigass with the cooler then most likely a stronger oil pump would be usefulOpps...Sorry. It's Oil Pump. But some ppl call it oil sump. Right?
