DIY- Lights Wire Tapping
edwin_lcw
Setapak
i bought lights ..... to light my car the part under the meter ..... but i dun 1 it to be on switch ...... i wan it to go on when to doors are opened .... then the lights follow .... but i dunn whare to tap the wire ...... can anyone teach me ?
hi,
check carefully around the door switch.there is a black rubber tap covered the switch.take it off then you will see the switch.find the wire out but remember that the switch only for POSITIVE wire(+),fix the NEGATIVE(-) wire at any metal screw will do...keep in touch if you don't understand what am i talking about...
i only got one wire going to the switch worr ..... the other one going to -ve of the battery
just wired any of the screw in the car which is screwed bound to the car chassis.
That will do the trick.
hi edwin,
what kind of light were you bought??the fluorescent light??
if yes then forget about your plan because fluorescent need some time to light up so when you open and close the door just need a few seconds.fluorescent light cannot a while light it up then off it.the tube won't be lasting long...
and maybe the fuse also easy to burst...
think about it...
so the fluorescent lights ....... how ? got the diagram and lists of stuff i need ar ?
this type of light u need a electronic ballast wan
hmm... edwin_lcw, maybe u can refer to "undercarriage light" in this forum for some balast info or go to www.howstuffworks.com for more details :)
hi edwin,
fluorescent tube can't direct connect to battery.it will blow...
it must use a electronic choke(ballast)to light it up...
the comment to tell you is forget about the lighting function you wanted to do...
A thread every 60 seconds
