Discuss About Your Car...
bypas the emo, still cant start n formen found engine pressure not enough to start... is change engine is needed? cause formen ask to change engine.... got better advise?
Bro, this is your regular foreman Or u just walk in and state ur problem?
No such thing as simply say change engine. Pls go SC or get 2nd opinion. Maybe ur car is rip apart just pay the foreman to fix it back and get ur ass to other workshop.
I worry if ur car stay in this workshop, the cost will be same as 2 engine eventually.
What engine pressure? You mean the piston compression not enough pressure? If that is the case should still be able to start
Bro, I hate to say this so please excuse me. How did it go from an electrical issue to an engine one?
Your initial problem was engine cannot start. Large power drain and ecu/immobilizer resets. Then later it was fuel pump and ecu not receiving current. How did it suddenly become 'engine pressure not enough to start'
I mean no disrespect to your mechanic but from the flow of events, I currently have little to no confidence in him.
Later after change engine still got same issue, then what? Will he then suggest change car?
Please take the car and go to another mechanic for a second opinion.
This reminds me of one case. Car owner car jerking, send to mechanic, change plugs, no difference, change spark cable, no difference, change distributor, no difference, then don't know what else change here and there, finally his friend introduce him to my mechanic. My mechanic check then listen to his story say almost everything change still like that. So happen I was driving same model of this car, so he called me up, can bring my car to use some parts. Drove over he remove the electronic ignition transfer over and issue settled. Order a new unit fitted in and solved, but at the other mechanic he paid for many things blindly already......lol:rofl:
alot of mechanics nowadays macam tu... main bantai tukar je.... xtau troubleshoot.
New Posts
