Battery shift to rear boot
4g92mivec
216
Dear all zth sifu,
I'm planning to shift my battery to rear boot so i can obtain more space at my engine bay , however just a question roughly about how much a shop will charge for that & what kind of wiring it need ?
JaSON5878
98
Normally they use welding cable for the extension.
You can do it yourself too. But take a good care of the mounting & insulation.
coldfusionpower
157
planet earth
just get yourself welding cables for positive and negative from the front to the back, 4 x terminal block/terminal bus... easy to do ...
8229
118
6
Pull the welding cable from ur boot to ur engine bay, through the firewall (if not mistaken im share the hole for aircond...).
Connect battery +ve point to ur +ve car wiring, battery -ve point to ur car body at the boot compartment is enough.
Becarefull of the +ve terminal, warp it so that it wont touching to ur car body. -ve is no problem....
Warp the welding cable with thick rubber hose so that it wont scrach the cable at the point its thru the firewall, its happen to me when the cable was cut and touching the body, its like a very bad jerking at that problem, realize its when service the aircond. Thanks god it not burn my ecu.
Use good welding cable.. dont use thin one...
4g92mivec
216
Roughly about how much the welding cable from front to rear ?
stevenV6
1,380
any shops to recommend for doin this???........i'm interested too..........
Hello Everyone, I'm new to this forum :)
I'm looking to buy a half cut for a Honda civic ek9 or just a regular b16 half cut.
Please tell me any shops(address) in Kuala Lumpur that I can go there and buy, test the half cuts.
Thank you for your help.
