BOT (Bolt On Turbo)
poosiong
209
2
any sifu know?the RHF5 turbine is same wif TD04?or smaller or bigger than it?tq
Bump: any sifu know?the RHF5 turbine is same wif TD04?or smaller or bigger than it?tq
chrissyong
975
14
sure the rhf5 bigger than the td04 ,last time i try the 4g91 engine bolt on turbo,that is damn fast,i share some exp here, use toyota 4agze piston bore is over size 83mm low com , rod can use mazda b6,1.8mm metal gasket,add the king bearing,arp nut,custom make banana and td05 20g,510 evo injector,tail 38mm waste gate,gsr head set and gti cam,mirco tech lt10s, evo fly wheel + exedy super single, evo 2 gear box + drive shaff,sard fuel ragulator,wabro 255liter perhour,boost 2bar can get 400whp,can rev to 10k rpm,all cost is over rm 40k but that is really fast :biggrin::biggrin::biggrin:
Bump:
speed2horizon
2,798
334
1,683
Bump:
Bro, u sure toyota supercahrger piston got 83mm ka...? I'll suggest 4age conrods if to be used on a 77.5 stroke. at least u don need to think about the conrod modding at the piston part.
mrafif
52
1,508
hye~ i just want to ask from u guys~ does BOT will run smoothly with GEN 2 1.3 auto ? :driver:
Bump: hye~ i just want to ask from u guys~ does BOT will run smoothly with GEN 2 1.3 auto ? :driver:
Sky222
3,947
10
AU
AGREE ..... as what i know ..supercharged piston ...i dun think got 83mm
4G91 block Original piston size = 78.4mm
Upgraded to 83MM??!??!?!?? i think the block already BOCOR~ so I dun think the setup is right ...
4age conrods mod to 4G91 ??? i nv heard before...
Somemore Evo Flywheel mod into that gear box ??? its can install and doesnt fit nicely and there will be a trouble when drive....
and 510cc injector can support 400WHP?!?!?!? bro u sure or not .....
800cc Injector in my evo ...only can support 4xxwhp .....
then SARD / RC no need come out with aftermarket injector.. d
Base on logical side....... Normal Engine Block ........ the safest is Never bore more than 2mm ~~
speed2horizon
2,798
334
1,683
Well. 4age conrods on 4G91/92. Mod the crank.
Regardin the 2mm thing. Well, teh 4G91block and the 4G92 block basically came from the same mole. The only difference is the bore. That's what we call after cast machining. In other words, whatever maximum bore size that a 92 can cope, it can be coped by a 91.
Nothing wrong with EVO 3 flywheel into EVO 2 gb. But what's the point..?
And, 20g..??? Sure boh..? mae lag like hell..? Even GSR facing the same problem when plunge in a 16g EVO 3 which is suppose to be lighter.
And 4G91 400WHP...? Hehehehe.... Think twice before u say man... :thefinger::thefinger::thefinger:
And regarding the Campro BOT. And 2WD AUTO GB for NA car will never last more than 1/2 years when the car is turbocharged.
Regarding the BOT details, U need to find the engine specs, example bore size, stroke, CR etc. post it, then the otai otai will give suggestion.
Sky222
3,947
10
AU
hhahaha..... Speed2horizon ....
1 thing maybe u miss ....4G92 / 91 / 93 look almost the same ...but u didnt notice that the block thickness is different and the height its different for few mm,
because we try to bored 81mm...before at my workshop.
the block condition is very dangerous d.....going bocor soon...becoz inside the bored wall is water line........ n its very thin d...engine its damn hot wen running n temperature increase
and
Evo Flywheel is differrent ....its not about the gearbox and its about the ...engine block ...
gearbox is same but the block where flywheel is connected its different...
the Evo Flywheel ...got a bump came up from flywheel ...but 4G9x flywheel dun have .... :)
TD05 20G? im using now..... not so laggy lar .... 4100 rpm turbo only started ......
4xxwhp~~ :thefinger::thefinger:
speed2horizon
2,798
334
1,683
Just to let you know there is already some 4G91 BOT using 81mm supercharger pistons without any heating problem. Boosting at 0.9bar...
And I am already using MIVEC block now. plunge in Supercharger pistons. Result same as the 4G91. also 0.6mm protuded from the block... But 4G93 is higher. That one I know...
4100rpm under low compression... I can;t imagine how it feels...
But anyway...chrissyong pls...
Sky222
3,947
10
AU
wahh..someone using my setting d wor ...
speed2horizon ..when go out yam char long time nv see u d lar~~~~~~~~
hanslin
216
4
:wavey:yes! but but u need to take$$$$ coz by drive by wire trottle body n std comp. Not too high power if not the trans will go away!!!:cheers:
speed2horizon
2,798
334
1,683
Yamen, long time no see. has been quite busy these days... U know lar, year end jor... Alot of stuff need to conclude...
WEll, about my car, Cause new pistons + new blocks + new rings + new bearings... Need to run in, hehe.... scared lar...
Sky222
3,947
10
AU
call me yam char with free.. heheheh
my engine just overhauled with new Oversize Supercharged Piston + ARP Stud + Kings Bearing need to run in too ~~ feels like wanna go kl -terengganu - kl
rattan
1,813
27
1,648
www.itswat.com.my
Anyone BOT Perdana V6 before ?
ok i'm planning to buy these things and pretty amateur questions. lol cause im just starting.
i know what they do but my problem is it all i have to do is install em in my car then no more modifications like if do buy this then i have to buy that too. get my point ?
also is it maintenance free ? then if not what are the things must do.
