I plan to Bolt On Turbo to my Swift with a M15A Powerhouse......
The question is,if i custom the Manifold myself and bolt it on myself,will it be a hard job? as i have no experience on bolting on a turbo to a non-turbo engine before,i assume that i just need to replace the Extractor to a Turbo/Banana Manifold,make a hole in the sump to let the turbo oil drain back into,get a oil supply either from oil press sensor mount or oil filter ..... but im not sure about this =S
The Main question is.....will the engine without any internal mods survive with the boost from the turbo,if it will how much boost pressure should i set and what is the max ?
Heard that some people said that i ill need to replace my stock injector to a larger CC one and replace or add another Fuel Pump which have a higher LPH value.....but how can i find out how large the Injector need to be and how high the LPH need to be,is there is anyone can shed a light about this?
Thanks very much for any answer =)
