BOT Kakis, LAI LAI LAI...
donCityZ
2,230
33
1,648
Fowar... so long i not hang in here... its like back to future or something..
Finallly will be doing BOT to my car since got budget liao. Got some lobang to do it
at fren's fren's place.
So those BOT kakis (only BOT, not whole engine transplant kakis), can u
share these things
1. how long have you had BOT?
2. do u use 2nd hand parts (turbine, intercooler etc) or brand new
3. what is your frequent service item related to BOT?
4. what is your major repair done related to BOT?
Reason im asking, is, i want to do this first time right.
Also, anybody know how to get BOV tat sound like a turbo flutter or not? :biggrin:
Kamsiah bros.
donCityZ
2,230
33
1,648
Wah liao.. nobody knows aH? :driver:
speed2horizon
2,798
334
1,683
Maybe not the thread problem.... U can continue in the BOT section.
xinghonh
1,415
7
4g93p BOT reporting here
running on the streets with 1 bar boost for omost 3-4 years aredi
nuthin so far...wear and tear parts..and every 4k just do ur normal service
problem so far...every i have to top up my engine oil every 2k km
calvin9683
1,768
171
3,163
JB
For the BOV sound u r askin... Get those blow-in ones....
The ARC blow-in hav the nicest sound I've heard so far....
ixeo
4,788
3,080
KL, Malaysia
recirculate?
calvin9683
1,768
171
3,163
JB
Yea... I suppose dat's the correct word to use....
If not then it'll b sheepdog BOV....
artnet
1,514
Sarawak
www.cardomain.com
hi, i wander if those taiwan made intercoolers are efficient enough?
see quite a few brands for sale on net, jasma, arc, apexi, hks style so on...
fastlearner
136
9
Kota Damn
Suzuki Swift BOT reporting in :biggrin:
Installed BOT last 2 months, so far no probs, fingers crossed
All new
Just normal service last week with Motul 300V, almost bankrupt, haha
The rest are fine
Nothin so far, just feel that I need low temp thermostat & aluminum rad to make sure no overheat problem
Hope we can share more infos bro!
cush86
44
8
508
prado 3rz-turbo t3/t4 gtxr .82 rear
Just installed a month ago.
All new
nothing , still new:)
problem i encountered.
engine die alot when i release gear due to my stock airflow sensor problem.
emanage blue cannot handle change of injectors.
sending in again for new LT10's,injectors,bosch coils and slightly higher boost:)
dyno graph macam NA graph,no turbo surge at .3 bar:(
how is your boT coming along?
Turborized
138
19
518
I suggest you to get a new/recon turbo.
Turbo manifold/intercooler/sqv/Wastegate can get 2nd hand I guess, as long as there is no leaking or cracks.
