Are Lightweight Rims worth the investment?
I have seen a few test comparisons before by some international media. Coz they measure power on wheels, got slight increase when changing to lighter wheels.
you got any links? Interesting how a heavy rim saps power
thanks all.
I'm looking at advanti rims because most aftermarket lightweight rims do not have pcd 4 x 114.3 which renders limited choices.
have you all heard from Kean Lee Hin store at jalan ipoh, which is one of the authorized supplier for Advanti rims?
Will the gap between the fender and the tyre look weird with aftermarket lightweight rims?
Yes, Kean Lee HIn is YHI dealer, Yokohama tyres and YHI deal in a few brands of rims.
Get the correct offset and tyre size, then will look good. Want to rims to look bigger need to get the design with the spokes reaching the edge of the rims....
sanekit
Dec 9, 2015
1,616
157
nowadays the standard offset for 15" is always +35. hahaha. go all shops, +35. if want specific offset then need to order.
YHI is the same as YHI Advanti with its plant ni Bukit Rambai?
My son's Swift also now use 15x7 et35 coz it's the best offset to just lineup with the fenders.
Here are some newer ones:
I dunno man.
the 2nd and 3rd video examples show a difference in diameter. Hypothetically - If traction wasn't a factor - switching from a 15" to 12" tyre and wheel package would technically increase acceleration for a car. However if the same car switched from 15" to a lighter 15" with the same HP (power), then acceleration should improve which is what I've been saying - response. It doesn't increase HP.
Engineering explained talked about rotational mass - that one I can agree. I'm trying to apply the concept in my head and it's giving my headaches. His bicycle wheel example compares one low profile vs one high profile wheel and according to his theory the higher profile wheel will be quicker to roll down the hill even though both are the same diameter. But in a real car situation - a smaller wheel bigger profile tyre wouldn't deliver the same kind of blistering performance feel due to tyre flex and probably other things I don't understand.
Right now I'm talking about improving performance by means of response, ie-acceleration resulting from changing 15" heavy to 15" lightweight rims.
Can an asian dude with good maths please come in explain to us if this improves HP as well? Because I don't think it does. I agree it improves acceleration because the rotational mass is less but does higher acceleration = higher HP? Or just less resistance to the torque needed to turn that mass?
I dunno man.
The difference in diameter is just the wheels but not the overall diameter, at least not significantly. But the weight difference are significant there. This is talking about transferring power to the ground. If there's no additional power going to the ground to move the car quicker then what does?? Power at the engine is the same but there's not as much loss used to rotate the mass of the wheels hence enabling the power more to move the car.
Hello
Need some help from u guys :biggrin: my 'nenas' (exhaust part) produces noise. its like shaking/rattling when my car is idle or cruising at low rpm. please help me :banghead: ... before this the exhaust works ok. i use satria neo cps
