mira l2 brake problem
Aug 23, 2013
4
my l2 brake something wrong, sometime need press the pedal very down to brake the car.
already change new brake pads, brake pump no leaking.
anyone know how to solve its? thx...
jerrysiow
407
146
Seremban
Do brake bleeding on all 4 brakes and check the brake hose condition. If the brake hoses are old, upgrade to steel braided brake hose.
bubuooi
4
thx all....
my brake servo sudah upgrade to l5, servo vacuum hose juga sudah tukar baru...
the brake still same, sometime ok, sometime need press very down...
jerrysiow
407
146
Seremban
thx all....
Bro, take 1 liter of dot 4 brake fluid and ask the foreman do the bleeding again (keep on pump the fluid until the fluid come out is clean). Bleed all the 4 brakes until you feel there is a good bite (like normal, not deep deep style).
yh4everlim
42
5
1,508
Selangor
did u check ur rear brakes?? ur brake shoe or brake cylinder aka brake pump also will cause the problem, if the problem is not constantly, n the servo vacuum hose been chg, and done bleeding, mostly is from the servo.. sometimes master pump leak into servo cant be seen... especially l5
I'm using a wira 1.5 carburator engine........can i switch my standard engine to turbo engine?.......plz any sifu tell me! izzit possible?
