daihatsu mira question.....
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
For L5 4 cyl or 3cyl?
If 3 cylinder me think can because L5 3cyl (code EF-RL) have the same bore size with L2 (code EF-JL) i.e. it got 68mm bore and 60.5mm stroke
and... you loose 0.5mm of compression ratio if using L2 piston (8 vs 8.5)
source:
Daihatsu L2S spec list
Daihatsu L5 spec list (3cyl ver)
If 4 cylinder (code JB-JL), you have to rebore a lot because it has 61mm bore and 56.4mm stroke
source:
Daihatsu L5 spec list (4cyl ver)
4gbanger
Jun 26, 2013
1,958
386
683
Johor/ShahAlam
If ur engine is a L5 3 cylinder, my advice is to just rebore your L2 sleeve and install a Kelisa (1.0cc) piston. although its a low compression piston, but it can withstand boost up to 1.8 bar with no management and the engine last quite long until the gearbox kaput and the kancil is now total lost due to accident.. :idea:
hi. i need help in installing a hks bov ssqv on a perdana v6 n/a. i heard that by placing this item on the air cleaner pipe and your intake manifold( fuel
injection ) will enable the pressure to come out the swoosh sound. is it true? but anways, anyone care to show me where is the air cleaner pipe and the intake manifold (fuel injection)? if theres a pic would be better. thx. :)
