Rear brake system : Drums in disc / seperate handbrake mechanism
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
As the title suggest,
Why does manufacturer apply such system. For example, the olw Merc W124 is equipped with a rear brake disc but the handbrake is using a drum and brake shoe. It looks like any normal disc because we cant see the mechanism on the inside center hub of the disc.
Other vehicle using is is the Pajero Sport.
Some conti cars are using seperate smaller caliper on the rear disc as handbrake.
Why do they do this?
I read online someone said its to prevent the disc from being warped or damaged or pad stuck to disc due to heat concerntration if the handbrake is applied after a very aggressive or spirited drive.
My Chery SUV and Subaru Forester both having this system......
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
actually drum brake system have better grip within smaller diameter of effective pad radius....
and with just cable operating separately than the rear brake caliper....less failure to happen... also easier maintenance...
this is common on higher range and sportier range car...
  • Like
Reactions: gunnerzz
That is what my mechanic explained also. More contact surface. Use for handbrake is good, but not for brakes as drums cannot cool as fast as disc which is in the open, where drums are enclosed.....
gunnerzz
2,109
695
713
38
Melaka
parking brake using rear brake pad is that complicated and prone to failure?
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
yea..its abit complicated and often not good enough grip when parking...
plus there is safety net when the hydraulic brake caliper fails, the car can be safely stopped using parking brake since it was running a separate system...
We reported recently that Tony Fernandes has acquired British sportscar manufacturer Caterham. The Team Lotus principal did so by buying out Caterham’s previous owners, Corven Ventures, and was listed as a director of Caterham on 12 April. Nonetheless, Fernandes elected to keep Caterham’s current Managing Director, Ansar Ali, at the helm...
