my 4 throtle is calling cleaner
how much?
rm 100 reasonable?
injector cleaning rm 140 reasonable?
thanks 4 comments
how much?
rm 100 reasonable?
thanks 4 comments
about this one not quite sure...must wait till dry if spray with engine off then can start d engine?
yup...sure miss that fellar...If EFN still around then RM80 gaodim....somemore damn clean...
you can cheat the AFM in order to start the silvertop engine with open throttle. Just use a tape to tape the AFM flap to make it half open then u can start the car without the plenum cover.mine is svt
air flow sensoring
cant do d cleaning s u said
once remove d cover cant get d engine start
sorryyou can cheat the AFM in order to start the silvertop engine with open throttle. Just use a tape to tape the AFM flap to make it half open then u can start the car without the plenum cover.
