WTA: 4age 20v svt 4 throtle cleaning (help!!!)
chinozie
Very Young Member... :D
3,429
170
5,163
Damansara
4age20v.blogsome.com
the whole Throttle body...lorrr...that's the best way...totally refresh...if not taken out...then you can DIY...just buy a carb cleaner, spry it inside the TB, ISCV n fuel railing
chinozie
3,429
170
5,163
Damansara
errkkk...svt...ajiooo forgot...
sorry bout that...
then have to open the TB for best result...
must wait till dry if spray with engine off then can start d engine?
about this one not quite sure...
can someone clarify it ?
wilm3
500
29
If EFN still around then RM80 gaodim....somemore damn clean...
weitak_83
201
Cheras
i got d throttle & injector cleaned at tmn. len seng, kl cheras
BG products
RM 280, terrible?
able 2 feel a bit of power increase but jerking more often
suppecting d denso iridium spark plug not working properly
any comment?
EG9
2,309
37
Subang Jaya
mine is svt
air flow sensoring
cant do d cleaning s u said
once remove d cover cant get d engine start
you can cheat the AFM in order to start the silvertop engine with open throttle. Just use a tape to tape the AFM flap to make it half open then u can start the car without the plenum cover.
weitak_83
201
Cheras
sorry
im still fresh in automotive
where is d AFM flap?
hope u don mind 2 show me with pictures
thanks
Guys
I just had my alternator replaced. After that, I see my idle rpm is very low, around 500 (before this ok, around 1k). During alternator installation, I see the mechanic remove both terminals of the battery too.
Is it because of the ECU being reset? How to get it to normal idle rpm? Should I go to workshop, spend RM50 for them to properly set my ECU back (using that device which they plugged in it under the dashboard, I duno the name :confused:)? Appreciate all inputs. Thanks.
