if exedy 3 puck or 4 puck +heavy duty clutch the vibration only when release clutch.
in your case when tekan minyak or accelerate the most probabble is your inner cv.
how to check?no other choice other than have to dismantle the drive shaft and check for free play in the inner cv joint or no grease at all,try to rotate the cv joint when you pull the driveshaft out.most mechanic know how to check.check the cv cover as well.
based on experience,usually the knackered cv joint is on the reverse side of the vibration.let's say you experience vibration at left,the right one is the problematic one,sometimes can be both.
the easiest way is to get recon cv joint,and the knakered one send for recon and keep as spare parts.
