vibration...
fazidk
3,163
413
5,183
hello again frens...got a problem here hope any1 can help advice or troubleshoot dis problem..went to a few mechanics already stil x rectified..:adore:
there is a vibration whenever a left turn is made (x prob when turning right)..or when moving from standstill eg traffic lite....anyone of d workshop i went to said its d drive shaft problem..at 1st i thought d same..all d cv joints were replaced..now here is d issue....
it still vibrates..to add to dis problem (i x seem to figure out y..) it DOES NOT vibrate when making d left turn while d clutch is pressed or on free gear..
anybody?sifus? pls help
tq n rgds
fazid
019-3097725 :hmmmm:
oh ya n another thing...
any1 can tell me wat factors determine usage of drive shafts (hope i got d question rite)..i mean say u drive a proton 1.5 rite...wiz a evo3 or vr4 engine..1.8gsr lock 2-wheel gearbox..WAT DRIVE SHAFTS (WHICH MODEL) DO U USE? STIL USE D ORI 1.5 SHAFTS? OR VR4/E3 (IF THEY R D SAME) SHAFTS?
in other words drive shaft is determined by d engine or gearbox used or????
tq so so much
rgds
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
errr...determined by the gearbox and knuckle that u use...
if different set means have to kacuk driveshaft follow GB model and CV joint at knuckle follow knuckle model....
:adore:
fazidk
3,163
413
5,183
oh tq so so much bro gtr...will try check wiz d mechanic...if i have 2 use back d gsr gb, are there any proton ds dat is d same?i mean if im using gsr which is 1.8 gb,is it possible 2 use a proton 1.6 or 1.8 gb say from a wira or satria etc etc?
tq again..peace
fazid
019-3097725
:adore:
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
not sure about what would fit....
wait2...are u using LSD type gearbox??if yes only driveshaft for that LSD gb can be fitted.....
but not sure what caused the vibration....
Fazidk : I experienced a similar problem in my Toyota Unser. In the end all I did was change the oil in the erm... axle oil? Not sure what you call it. Rear axle has this ball bulge, just changed the oil there and problem solved.
fazidk
3,163
413
5,183
eh x bro..sori left dat detail out...mine is lock 2-wheel gsr gb NO lsd...
dennisdreams
333
21
4g93 turbo geabox? you were using the 4wd which lock the rear diff output shaft??
which concern is the CV joint you had change is the gearbox side or the wheel side?
was the ball bearing inside the CV joint @ the gearbox side (5~7 of them) inspected?
fazidk
3,163
413
5,183
ermm bro dennis..i think its d left side (both wheel n gb cv) since d noise/vibrations only comes when i turn LEFT..n of coz s mentioned..while moving from standstill
fazidk
3,163
413
5,183
anybody???can offer me other advice...
tq rgds
[H] [K] [S]
1,130
616
tq again..peace
fazid
019-3097725
Had a friend used a 1.3 GB on a Satria VR4 several years back. Just the ratio kinda short tho...
dennisdreams
333
21
the GB mount should be compatible with all 4G series engine's GB, from the way you said, if it's vibrating when your car moves from stand still, really high possibility you had a faulty / miss alignment CV joint~
fazidk
3,163
413
5,183
oh ok thnx bro dennis...i was thinking d worse..one of my frens mech said d DS "panjang" watever dat means...wat do u think bro?
if faulty/miss allignement CV joint means replacing d CV joints bro?
thnx again n rgds
fazid
fazidk
3,163
413
5,183
taken into account:
- d kind of gb im using (1.8 gsr locked 2-wheel)
- pcd 114.3 from vr4 (4 lugs)
if i were to chnge d cv joint (gearbox side), from wat proton model is compatible?
tq
DanzEterna
15,911
3,371
3,213
PJ
www.primeperdanaclub.com
bro, could u elaborate more on your symthomes.
1. Driveshaft - car will vibrate from a standstill till moving
2. engine mounting - car will vibrate during standstill
3. when making u turn your steering does not tendang balik to its original position - lower arm or tierod end.
4.got knock knock sound when going over bumps - lower arm.
5.your DS depends on the gbox yr using. but only 1 side.....i think so :)
fazidk
3,163
413
5,183
thnx bro danz...d following:
1. Driveshaft - car will vibrate from a standstill till moving..YES IT DOES ACTUALLY
2. engine mounting - car will vibrate during standstill..NOT DAT I NOTICE
3. when making u turn your steering does not tendang balik to its original position - lower arm or tierod end..CONFIRM NOT :)
4.got knock knock sound when going over bumps - lower arm....NO
5.your DS depends on the gbox yr using. but only 1 side.....i think so..HMMMM WHICH SIDE I WONDER
thnx again bro
:lol: jz 1 2noe how U ppl avoif from police U got ur car tinted especially when ur car tinted very dark 1! & police suddenly come??? :) HUH! HOW??? gif suggestions o opinions! THANX! :D
